Request for Data from TheHolyCow - Fuelly Forums
Old 07-10-2008, 03:41 PM   #1
Fuel consumption will be constant in any gear at 20% throttle and 2000 RPM only when the manifold vacuum reading is identical, and only for a short period of time.
regards
gary
Old 07-10-2008, 05:21 PM   #2
If throttle setting hasn't changed and engine speed hasn't changed, what would cause manifold vacuum to change? I think at any given throttle setting and engine speed, manifold vacuum should be pretty constant.
It's true that if you want to be very scientifically precise about things, there are other factors that need to be considered, like atmospheric pressure, ambient temperature, and engine temperature. Probably also the chemical composition of the fuel. But all those things are likely to not change much, especially within any given brief interval. So I think it's OK to simplify things and more-or-less ignore them. But maybe you're thinking of other factors that I've overlooked.
You seem to be saying that even if throttle setting, engine speed and manifold vacuum all remain constant, that after "a short period of time" there is something else that is going to cause fuel consumption to change. I can't imagine what that would be, so I hope you'll explain what it is.
Buying a Scooter SVOboy General Fuel Topics 3 03-30-2007 02:31 PM
Prius highway rpm? omgwtfbyobbq General Fuel Topics 14 10-23-2006 10:43 AM
New Fellow CRXer coldtotouch Introduce Yourself - New member Welcome 12 09-01-2006 04:16 AM
hi SuperRobot46000 Introduce Yourself - New member Welcome 6 07-15-2006 06:44 PM
possible switch to vbulletin tomorrow Matt Timion Fuelly Web Support and Community News 4 05-17-2006 10:31 PM
