Originally Posted by maxxgraphix
Would you care to enlighten me as to what you have done? I looked at your gas logs. Very impressive. Your car should only be at 26mpg.
That's a big question. Aside from the mechanical mods listed in my profile and driving techniques, there are many ecu mods. I'm lucky to have access to a commented disassembly of the factory ecu in my car, otherwise I wouldn't have found as many sections to change. The ecu mods are focused on reducing fuel usage at all times, such as:
leaned out startup enrichment
shortened the ammount of time that startup enrichment is active
leaned out cold ect enrichment
lowered idle at all engine temps (idles low when cold)
lowered rolling fuel cutoff threshold at all temps
lowered temp threshold where ecu switches from cold enrichment to warm enrichment
leaned out various O2 sensor switchpoints and targets
tweaked the timing and fuel maps so I can lug the motor with less harsh vibration
load based knock sensor management to control how much timing is pulled when the engine knocks, how long the timing is pulled, and when to ignore knock
added lean burn code with triggers for vehicle speed, throttle position, and airflow
adjustments to the EGR map
changed the code to match the bigger fuel injectors and upgraded MAF so they work like stock parts.
There may be more that I'm forgetting, but those are the major changes that made a difference.
