Power Steering Delete - Fuelly Forums
Old 04-21-2007, 02:49 PM   #1
I'd like to lose the power steering in my truck, a 98 Nissan Frontier. This truck was never offered with manual steering so there's no wat I can just swap parts. Can anyone recomend an electric motor to run the pump?
jdham137 is offline   Reply With Quote
Old 04-21-2007, 03:26 PM   #2
Just disconnect it..?
parasonic is offline   Reply With Quote
Old 04-21-2007, 03:54 PM   #3
Snax's Avatar
2nd generation MR2s were equipped with an electric power steering pump.
I would not want to even try to drive a pickup without power steering.
LiberalImage.com
I think, therefore I doubt.
Old 04-21-2007, 03:59 PM   #4
omgwtfbyobbq's Avatar
My buddy's dad had a 1 ton GM van w/o power steering. Not too bad unless you were totally stopped. Definitely a work out.
Old 04-22-2007, 07:33 AM   #5
I thought about just disconnecting it but I've been told that it's really dangerous to do so. It makes the steering even more difficult than manual steering. I think I'll need to check out the MR2 option.
Old 04-22-2007, 07:49 AM   #6
I'd try disconnecting it and seeing how difficult it feels before you do anything else (meaning buying things).
Old 04-22-2007, 08:27 AM   #7
Snax's Avatar
Agreed - somewhat.
While you can remove the belt and try it that way, it's probably a not a true picture of the effort required to steer without removing the pump from the system completely. In other words, when you turn the wheel, the fluid in the rack has to go somewhere. And unless there is a way to bypass it through or around the pump, it won't go easily.
The only way to get a true picture of how it will work is to bypass the pump or simply disconnect the lines to it. For testing purposes, you could probably just disconnect them at the pump and stick the ends into a catch can. The force required to clear the lines of fluid is far less without the pump in the mix.
LiberalImage.com
Old 04-24-2007, 09:28 AM   #8
my 73 f250 4x4 had the power assist (with a hydraulic ram on the linkage) and the pump blew up so i just pulled the belt off and drove it. it even has big 33x12.50r16.5 tires!
anyways, summit sells an electric motor meant for running a water pump for about 100 bucks (might not be a bad idea itself) perhaps you could get it to run your pump (maybe both?) the only thing there is that you would need a bigger pulley on the power steering pump because it takes way more power to run it than a water pump, so change pulleys to gain a mechanical advantage since you dont need the pump to run at more than 1000rpm.
just my .02
1987 volvo 740 turbo
smokes like a freight train!
~20.68 mpg
gasssaver87 is offline   Reply With Quote
no ethanol in prem. fuel ? JBW General Fuel Topics 17 11-02-2014 11:20 PM
Looks like the price you entered for a litre of gas is unrealistic. winstona Fuelly Web Support and Community News 6 05-12-2013 10:26 AM
Wrong MPG adefeatedman Fuelly Web Support and Community News 3 02-16-2012 08:35 AM
Over 100 Gallons twbhd04 Fuelly Web Support and Community News 14 06-20-2011 08:09 AM
Recommendations for a tire gauge Compaq888 General Fuel Topics 10 04-21-2006 02:18 AM
