Possible source of SS electrodes? - Fuelly Forums
Old 07-13-2008, 07:06 AM   #1
flapdoodle's Avatar
I noticed Walmart has some fancy travel mugs that are double walled stainless steel and claim to be insulated. Looking inside told me the inner container is cylindrical. Can't tell if the outside if the outside of the mug is SS or not, but it is sculptured rather than cylindrical.
The item is marked on the bottom as a Walmart product made in China. Cost is about $7
It may be possible to disassemble it and use the outer part as the HHO generator jar as well as one electrode, remove the insulation and use the inner cylinder as the other electrode.
Old 07-13-2008, 07:46 AM   #2
I've seen some similar mugs break. The ones I saw used dead airspace to insulate the mug, not foam. The best thing to do is just buy one and hack it apart, see what's inside. Here's another tip to find cheap SS mugs. Your local thrift shop. Many companies give travel mugs away as promotional items. They can often be had for $1 or $2 each, usually with a bank or computer company logo printed on them.
Old 07-13-2008, 08:03 AM   #3
I've got two double kitchen sinks I got from yard sales I'm gonna cut up.....
Old 07-15-2008, 07:12 AM   #4
GasSavers_Ryland's Avatar
stainless steel is a poor conductor of electricity, gold plated silver would be better platinum is what is normally used for electrolysis of water, and separating hydrogen from natural gas is what is done when you buy a tank of hydrogen.
Old 07-15-2008, 07:21 AM   #5
I think the reason Stainless Steel is used in these homemade applications is because it does not corrode or rust, and its a lot cheaper than platinum. How much money is a HHO setup that costs a few thousand dollars to build going to save you? Stainless Steel is more cost effective.
Old 07-15-2008, 07:31 AM   #6
flapdoodle's Avatar
What you say is true, but for our purposes the SS plate area is large so it makes little difference. Lead is a lousy conductor but is used for battery plates.
Anyhow, thanks for the tip. I will switch to platinum when the price falls to $4 an ounce.
BTW, I am using titanium for the negative electrode.
http://flapdoodledinghy.com/HHO_generator.html
A side project I am working on... DTMAce General Fuel Topics 3 04-29-2010 03:21 PM
2008 Yaris Sedan 5MT W/ Catback Magnaflow RningOnFumes Experiments, Modifications and DIY 0 03-04-2008 12:06 AM
New Member pinardk Introduce Yourself - New member Welcome 3 06-03-2007 04:38 AM
FAS'ing and engine temps zpiloto General Fuel Topics 32 06-12-2006 04:50 PM
