Peakster's First Formal Experiment a Success! - Page 2 - Fuelly Forums
Old 01-28-2007, 08:27 AM   #11
Tuggin at the surly bonds
Silveredwings's Avatar
N-n-n-n-nice J-j-j-job!
Old 01-28-2007, 11:25 AM   #12
GasSavers_roadrunner's Avatar
Nice experiment with mirrors IMO
Originally Posted by Peakster View Post
I just put the video of my experiment on YouTube. Enjoy!
Nice video, Peakster
GasSavers_roadrunner is offline   Reply With Quote
Old 01-28-2007, 03:10 PM   #13
Very nice test, thanks for sharing! I wonder how this translates to other vehicles though? Based on limited input, the results seem to be consistent with other Metro's but it isn't clear that you can transfer that to another model.
Just wondering.
-- Scott
GasSavers_scostanz is offline   Reply With Quote
Old 01-28-2007, 03:58 PM   #14
Peakster's Avatar
Just wondering.
-- Scott
Mostly likely it would be different with various model cars. For instance, if I ripped the mirrors off of The Chevy, I probably wouldn't see much difference at all because the truck has huge frontal area anyway.
Because the Geo metro gets higher FE numbers, than most cars, the mpg difference is much more readable than if I drove the truck which gets 15 mpg to begin with.
Old 01-28-2007, 04:39 PM   #15
skewbe's Avatar
Peakster, Thanks for doing and sharing. 70 MPH is probably the biggest factor IMHO. My average speed is 25 so it wouldn't help me much, but people who use the hiway a lot certainly have much more to gain with the aerodynamic improvements, ANY aerodynamic improvements.
scostanz, true enough, it could be that the mirrors are effectively blanked out from the shape/location of the windshield/bug guard/grille on another vehicle. You cannot say for certain that this transfers to another vehicle, certainly the exact numbers wont. But you can make the generalization that less frontal area equals less drag, so it probably will help reduce drag to some degree.
If you are going slow, then the mirrors offer better situational awareness and reduced blind spot, and I would keep them. Only if you spend most of your time going fast would I suggest *considering* shaving off your outside mirrors (and then consider replacing them with a camera or at least one of those multi angle wide interior jobbies).
Standard Disclaimer
Old 01-28-2007, 05:06 PM   #16
Or do like I did: compromise - delete the pass. outside mirror (inside replacement) and fold back the driver's side on the highway, and deploy it for city driving.
Neat vid, Peakster.
Old 01-28-2007, 05:13 PM   #17
kickflipjr's Avatar
That was a well done experiment. -25 Celsius? Brrrrrr.
2008 EPA adjusted:
Old 01-29-2007, 09:58 AM   #18
Team GasMisers5!
landspeed's Avatar
Thanks for publishing this . I am going to try mirrors off, and try to break the invisible barrier of 50.6 (UK) MPG - no matter what I do, I can't seem to get past the number!.
Regarding the drag of the mirrors, it has already been mentioned that they add to frontal area, and are placed in a position where the air speeds up due to being forced around the car.
There is also a long column of turbulence behind the mirrors - a few days ago, as a passenger, I held a cup of steaming hot tea (from a thermos) behind the mirror, and the turbulence was very well demonstrated!.
Hypomiler
Old 01-29-2007, 10:01 AM   #19
Team GasMisers5!
landspeed's Avatar
BTW, 0.2GPH is not bad for idle - it means that, coasting with engine-on at
30mph will be like getting 150mpg, while at 60mph, it will be 300 mpg!
Hypomiler
Old 04-26-2007, 09:22 AM   #20
Send a message via AIM to eivad1 Send a message via Yahoo to eivad1
if u get a bigger inside mirror the delete of the outside mirror is that legal
eivad1 is offline   Reply With Quote
Incorrect mileage calculation? tonedepear Fuelly Web Support and Community News 6 04-04-2011 12:04 AM
No EPA Est for 2007 Chrysler Town & Country jklaiber Fuelly Web Support and Community News 1 08-23-2008 12:15 AM
Motocycle Data pb Fuelly Web Support and Community News 12 08-18-2008 06:06 AM
WTB: HX or VX Wheels GasSavers_DaX Wanted to Buy 6 07-12-2006 09:50 PM
