P&G in a big Saturn - Fuelly Forums
Old 08-13-2008, 05:10 PM   #1
P&G in a big Saturn
I'm trying P&G with my LW 200 and I'm finding that this car responds well. I have been doing the +5 and glide to -5 of the limit. What I'm seeing on my scan gauge is astonishing this tank will be my best EVER 32.7 mpg and it may end up higher. I'll log results in my gaslog so everyone can see how it worked or didn't work.
Old 08-14-2008, 01:23 PM   #2
results are in 33.52 mpg I think I'll continue this trendand go for a 15+- Pulse glide and see if that changes anything.
Old 08-14-2008, 01:41 PM   #3
thornburg's Avatar
Originally Posted by philip1 View Post
results are in 33.52 mpg I think I'll continue this trend and go for a 15+- Pulse glide and see if that changes anything.
+15 could easily net you a ticket... are you friendly with the local officers?
(Note: Cost of ticket > cost of fuel saved by P&G, by a wide margin).
Old 08-14-2008, 01:59 PM   #4
GasSavers_BEEF's Avatar
why not try +5, -15 most cops won't say too much about you going under the speed limit as there is not a minimum speed on most roads other than highways.
try to stay on this side of the law if you can.
Old 08-14-2008, 02:17 PM   #5
my plan was not actually to exceed the limit by 15 but rather have a 15mph window for the P&G to occur instead of the 10mph I have been using.
Old 08-15-2008, 05:47 AM   #6
thornburg's Avatar
Ah, that's +/-7.5 (or maybe +5/-10), not +/-15 (which would be a 30MPH window). I'm thinking +/-15 would not be a tolerable way to drive, either for you or for the other people on the road. +/-7.5 or +5/-10 might be alright. I can tell you this, if I came up behind someone at 5 over, and they slowed down to 10 under (assume the road is a 50MPH limit, that means you were going 55, now you're going 40MPH), I'd be quite annoyed with them, and probably seeking to pass. Yes, not ideal Hypermiler behavior, I know, but I'm a recovering speed fiend, and still carry some of those traits.
Old 08-15-2008, 10:30 AM   #7
as am I .
I find the challenge worth the effort. and the goal of 40 mpg I think is attainable. it will just take time and practice.
Old 08-16-2008, 07:41 PM   #8
I would say to only go 5 under the limit if there are people behind you and it is a 2 lane road for courtesy sake. if there is no one else on the road, go as low as your top gear will let you. I drop out of overdrive around 35-40MPH. I try to stay above that.
Old 08-16-2008, 08:14 PM   #9
45 mph is the bottom limit of my top gear below that it will downshift (automatic). On backroads I never drop below -5 but on the highway 3 lanes a side I will go -10. This is a fun challenge eek out that last mile out of each gallon.
unplugged o2 sensor now better FE yzfdallas General Fuel Topics 5 04-25-2008 10:14 PM
Tire Pressure Inflation - what is too much? 1993CivicVX Automotive News, Articles and Products 11 09-23-2007 06:54 PM
FS: VW Cabrio EV in CO - cheap! $2800 MetroMPG Electric and Solar powered 5 08-21-2007 11:43 AM
Biobutanol: Discussion in the UK rh77 Automotive News, Articles and Products 8 01-24-2007 07:08 PM
Belated Intro GasSavers_brick Introduce Yourself - New member Welcome 4 12-22-2006 07:48 AM
