Oxygen Sensor Tweaking On ODB2 - Fuelly Forums
Old 04-21-2008, 09:24 AM   #1
I have this problem a Pontiac Vibe 2003 (toyota corolla/matrix platform) where if I do anything to adjust the A/F Ratio it just balances back to 14/1
So for I tried Eagle Research EFIE & a Camcom. But according to A/F ratio gauge(narrowband) it will learn out for a few seconds then eventually go back to the default mix.
Next step is to fool the rear O2 sensor because I believe somehow when learn burn exhaust hits the 2nd sensor the ECU knows to enrich the gas mix again or gives a P0420 check engine light.
I will do different runs this week with a EFIE on the rear O2 sensor & camcon controlling the front to try to achieve a lean mix.
I hope anyone else struggling with ECU problem this can offer ideas for me to try.
ProtonXX is offline   Reply With Quote
Old 04-21-2008, 10:03 AM   #2
Front sensor measures A/F ratio. Rear sensor measures catalyst efficiency.
GasSavers_landon is offline   Reply With Quote
The Monkeywrench Gang by Edward Abbey repete86 General Discussion (Off-Topic) 2 07-26-2008 09:58 PM
New Ride cartuch Introduce Yourself - New member Welcome 5 10-22-2007 02:02 PM
What next? billynjoanna Aerodynamics 19 09-05-2007 09:31 AM
Noob trying to save in gas! GasSavers_Bigfoot Introduce Yourself - New member Welcome 1 05-31-2007 12:17 PM
