OBDII CarPC MPG Calculator - Page 2 - Fuelly Forums
Old 10-05-2007, 08:02 PM   #11
Wow, you are awesome. I just got an email back from the developer and he said to look at stty also.
Thanks!
Old 10-06-2007, 02:11 AM   #12
skewbe's Avatar
thanx,
BTW, the MPG function I mentioned has a bug, they never convert tSpeed from kph to mph.
ref: http://prj.perquin.com/obdii/ under the "Tester Commands" section
Standard Disclaimer
Old 10-06-2007, 08:36 PM   #13
Using your advice with the command stty I got to the point of seeing the raw traffic from the scanner with minicom. I put the command into the perl script and it doesn't complain about it but it errors trying to find readable codes. I will work more on it later.
Old 10-06-2007, 09:52 PM   #14
cfg83's Avatar
Fourthbean -
Can you tell me which you bought? Did you buy this one for GM products? :
ElmScan VPW Scan Tool - P/N: 420300
http://www.scantool.net/products/pro...products_id=12
Thanks,
Old 10-06-2007, 10:23 PM   #15
Yes, that is the one I bought. And I opted for no case to knock off 15 bucks from the price (I am cheap).
Old 10-19-2007, 04:59 AM   #16
I have been poking around and it looks like what I need is to find what PID coming from my OBDII port is the injector duty cycle/pulse width or something of the sorts. Looks like it should be there, but it is not published anywhere so I will need to find it .
The scanner I have can be set to monitor all parameters being spat out from the port, so I guess I would need to turn that on and log it and then decipher and eliminate until I could find what I need (assuming it is there somewhere). Might be a bigger job than I think.
Old 10-19-2007, 06:33 AM   #17
skewbe's Avatar
Yes logging would be good.
Look for the following PIDS coming out of your computer:
$PID07 (fuel trim)
$PID0D (Vehicle Speed)
$PID10 (MAF)
if you don't have PID10 (MAF) then look to see if you have:
$PID07 (fuel trim)
$PID0B (Manifold Pressure)
$PID0F (intake air temp)
$PID0C (RPM)
Standard Disclaimer
Old 10-20-2007, 02:40 AM   #18
cfg83's Avatar
Fourthbean -
In the "scantool" program I can run in DOS or Windows, I get source code. The BOLD values are the ones I am receiving from elmscan in scantool :
Code:
static SENSOR sensors[] =
   // formula                        // label            //screen_buffer  //pid  //enabled // bytes
   { throttle_position_formula,     "Absolute Throttle Position:",     "", "11",      1,    1 },
   { engine_rpm_formula,            "Engine RPM:",                     "", "0C",      1,    2 },
   { vehicle_speed_formula,         "Vehicle Speed:",                  "", "0D",      1,    1 },
   { engine_load_formula,           "Calculated Load Value:",          "", "04",      1,    1 },
   { timing_advance_formula,        "Timing Advance (Cyl. #1):",       "", "0E",      1,    1 },
   { intake_pressure_formula,       "Intake Manifold Pressure:",       "", "0B",      1,    1 },
   { air_flow_rate_formula,         "Air Flow Rate (MAF sensor):",     "", "10",      1,    2 },
   { fuel_system1_status_formula,   "Fuel System 1 Status:",           "", "03",      1,    2 },
   { fuel_system2_status_formula,   "Fuel System 2 Status:",           "", "03",      1,    2 },
   // Page 2
   { short_term_fuel_trim_formula,  "Short Term Fuel Trim (Bank 1):",  "", "06",      1,    2 },
   { long_term_fuel_trim_formula,   "Long Term Fuel Trim (Bank 1):",   "", "07",      1,    2 },
   { short_term_fuel_trim_formula,  "Short Term Fuel Trim (Bank 2):",  "", "08",      1,    2 },
   { long_term_fuel_trim_formula,   "Long Term Fuel Trim (Bank 2):",   "", "09",      1,    2 },
   { intake_air_temp_formula,       "Intake Air Temperature:",         "", "0F",      1,    1 },
   { coolant_temp_formula,          "Coolant Temperature:",            "", "05",      1,    1 },
   { fuel_pressure_formula,         "Fuel Pressure (gauge):",          "", "0A",      1,    1 },
   { secondary_air_status_formula,  "Secondary air status:",           "", "12",      1,    1 },
   { pto_status_formula,            "Power Take-Off Status:",          "", "1E",      1,    1 },
   // Page 3
   { o2_sensor_formula,             "O2 Sensor 1, Bank 1:",            "", "14",      1,    2 },
   { o2_sensor_formula,             "O2 Sensor 2, Bank 1:",            "", "15",      1,    2 },
   { o2_sensor_formula,             "O2 Sensor 3, Bank 1:",            "", "16",      1,    2 },
   { o2_sensor_formula,             "O2 Sensor 4, Bank 1:",            "", "17",      1,    2 },
   { o2_sensor_formula,             "O2 Sensor 1, Bank 2:",            "", "18",      1,    2 },
   { o2_sensor_formula,             "O2 Sensor 2, Bank 2:",            "", "19",      1,    2 },
   { o2_sensor_formula,             "O2 Sensor 3, Bank 2:",            "", "1A",      1,    2 },
   { o2_sensor_formula,             "O2 Sensor 4, Bank 2:",            "", "1B",      1,    2 },
   { obd_requirements_formula,      "OBD conforms to:",                "", "1C",      1,    1 },
   // Page 4
   { o2_sensor_wrv_formula,         "O2 Sensor 1, Bank 1 (WR):",       "", "24",      1,    4 },    // o2 sensors (wide range), voltage
   { o2_sensor_wrv_formula,         "O2 Sensor 2, Bank 1 (WR):",       "", "25",      1,    4 },
   { o2_sensor_wrv_formula,         "O2 Sensor 3, Bank 1 (WR):",       "", "26",      1,    4 },
   { o2_sensor_wrv_formula,         "O2 Sensor 4, Bank 1 (WR):",       "", "27",      1,    4 },
   { o2_sensor_wrv_formula,         "O2 Sensor 1, Bank 2 (WR):",       "", "28",      1,    4 },
   { o2_sensor_wrv_formula,         "O2 Sensor 2, Bank 2 (WR):",       "", "29",      1,    4 },
   { o2_sensor_wrv_formula,         "O2 Sensor 3, Bank 2 (WR):",       "", "2A",      1,    4 },
   { o2_sensor_wrv_formula,         "O2 Sensor 4, Bank 2 (WR):",       "", "2B",      1,    4 },
   { engine_run_time_formula,       "Time Since Engine Start:",        "", "1F",      1,    2 },
   // Page 5
   { frp_relative_formula,          "FRP rel. to manifold vacuum:",    "", "22",      1,    2 },    // fuel rail pressure relative to manifold vacuum
   { frp_widerange_formula,         "Fuel Pressure (gauge):",          "", "23",      1,    2 },    // fuel rail pressure (gauge), wide range
   { commanded_egr_formula,         "Commanded EGR:",                  "", "2C",      1,    1 },
   { egr_error_formula,             "EGR Error:",                      "", "2D",      1,    1 },
   { evap_pct_formula,              "Commanded Evaporative Purge:",    "", "2E",      1,    1 },
   { fuel_level_formula,            "Fuel Level Input:",               "", "2F",      1,    1 },
   { warm_ups_formula,              "Warm-ups since ECU reset:",       "", "30",      1,    1 },
   { clr_distance_formula,          "Distance since ECU reset:",       "", "31",      1,    2 },
   { evap_vp_formula,               "Evap System Vapor Pressure:",     "", "32",      1,    2 },
   // Page 6
   { o2_sensor_wrc_formula,         "O2 Sensor 1, Bank 1 (WR):",       "", "34",      1,    4 },   // o2 sensors (wide range), current
   { o2_sensor_wrc_formula,         "O2 Sensor 2, Bank 1 (WR):",       "", "35",      1,    4 },
   { o2_sensor_wrc_formula,         "O2 Sensor 3, Bank 1 (WR):",       "", "36",      1,    4 },
   { o2_sensor_wrc_formula,         "O2 Sensor 4, Bank 1 (WR):",       "", "37",      1,    4 },
   { o2_sensor_wrc_formula,         "O2 Sensor 1, Bank 2 (WR):",       "", "38",      1,    4 },
   { o2_sensor_wrc_formula,         "O2 Sensor 2, Bank 2 (WR):",       "", "39",      1,    4 },
   { o2_sensor_wrc_formula,         "O2 Sensor 3, Bank 2 (WR):",       "", "3A",      1,    4 },
   { o2_sensor_wrc_formula,         "O2 Sensor 4, Bank 2 (WR):",       "", "3B",      1,    4 },
   { mil_distance_formula,          "Distance since MIL activated:",   "", "21",      1,    2 },
   // Page 7
   { baro_pressure_formula,         "Barometric Pressure (absolute):", "", "33",      1,    1 },
   { cat_temp_formula,              "CAT Temperature, B1S1:",          "", "3C",      1,    2 },
   { cat_temp_formula,              "CAT Temperature, B2S1:",          "", "3D",      1,    2 },
   { cat_temp_formula,              "CAT Temperature, B1S2:",          "", "3E",      1,    2 },
   { cat_temp_formula,              "CAT Temperature, B2S2:",          "", "3F",      1,    2 },
   { ecu_voltage_formula,           "ECU voltage:",                    "", "42",      1,    2 },
   { abs_load_formula,              "Absolute Engine Load:",           "", "43",      1,    2 },
   { eq_ratio_formula,              "Commanded Equivalence Ratio:",    "", "44",      1,    2 },
   { amb_air_temp_formula,          "Ambient Air Temperature:",        "", "46",      1,    1 },  // same scaling as $0F
   // Page 8
   { relative_tp_formula,           "Relative Throttle Position:",     "", "45",      1,    1 },
   { abs_tp_formula,                "Absolute Throttle Position B:",   "", "47",      1,    1 },
   { abs_tp_formula,                "Absolute Throttle Position C:",   "", "48",      1,    1 },
   { abs_tp_formula,                "Accelerator Pedal Position D:",   "", "49",      1,    1 },
   { abs_tp_formula,                "Accelerator Pedal Position E:",   "", "4A",      1,    1 },
   { abs_tp_formula,                "Accelerator Pedal Position F:",   "", "4B",      1,    1 },
   { tac_pct_formula,               "Comm. Throttle Actuator Cntrl:",  "", "4C",      1,    1 }, // commanded TAC
   { mil_time_formula,              "Engine running while MIL on:",    "", "4D",      1,    2 }, // minutes run by the engine while MIL activated
   { clr_time_formula,              "Time since DTCs cleared:",        "", "4E",      1,    2 },
   { NULL,                          "",                                "", "",        0,    0 }
Old 10-21-2007, 12:11 AM   #19
That looks to be in line with what I was getting in windows with scantool. I haven't had a chance yet to log any data from the port, the thought of sorting through it all makes me squeamish .
I guess a good way would be to get a filter to get rid of any EPA set pid values and then sort through the rest to see what is available.
I am currently working on getting the computer set up to the point I can listen to something on the way to work. So that has taken higher priority for the moment.
Old 10-21-2007, 01:27 AM   #20
cfg83's Avatar
Fourthbean -
No problem, I am doing my own contortions. One problem I am having is that the elmscan doesn't seem to "sync" or connect to the OBDII port. If the red LED is flashing, I am connected and ready to gather data. If the red LED is solid, then the PC is unable to connect to the elmscan. I can get the flashing red LED maybe one time in 30 connects (aka plug it into the car's OBD II socket). I submitted a ticket into the scantool support service.
I am hoping this freeware offers datalogging I can post-process, until I can (hopefully) get my own program running :
http://www.obd2crazy.com/wOBDv140/index.html
Here is an example image of my car :
Attachment 998
Not very precise mpg calculation larjerr Fuelly Web Support and Community News 4 08-20-2012 02:03 AM
Keeping my distance in traffic khurt General Fuel Topics 8 09-07-2008 04:23 AM
1986 toyota celica - a work in progress 86Celica Introduce Yourself - New member Welcome 22 01-07-2007 05:43 AM
Electrical power and cars. DracoFelis Automotive News, Articles and Products 2 09-16-2006 02:31 PM
