New to HHO need some ideas! - Fuelly Forums
Old 05-17-2008, 07:13 PM   #1
Smile New to HHO need some ideas!
I am trying to add an HHO generator to a truck. I have several questions I hope some one on here can answer.
1) What mixture should I put in the generator? & How much of each?
(distilled water, baking soda, vinegar ext.)
2) What is the best design and products to make the generator out of?
Anyone have any pictures and or information to share would be great. Any advice at all will be appreciated.
snapdragon is offline   Reply With Quote
Old 05-17-2008, 07:29 PM   #2
civic_matic_00's Avatar
here's some links that might help:
http://waterpoweredcar.com/hydrobooster2.html
http://www.fuelsaver-mpg.com/documents.html
http://www.alternative-energy-resour...uel-store.html
http://peswiki.com/index.php/OS:Water_Fuel_Cell
good luck.
civic_matic_00 is offline   Reply With Quote
Old 05-19-2008, 05:31 AM   #3
ZugyNA's Avatar
I'd start here:
http://smacksboosters.110mb.com/
Run it derated at maybe 10 amps to start and go from there? Need to keep it cool...best place is in front of the radiator if possible?
Old 05-20-2008, 06:34 PM   #4
simple
http://www.free-energy-info.co.uk/Hotsabi.pdf
and cheap
rangerbentman is offline   Reply With Quote
Old 05-21-2008, 04:18 AM   #5
ZugyNA's Avatar
That is some pretty easy construction...I think it's been criticized a lot due to the simple bolt used for the + side? But that doesn't mean much if there are good mpg results. I think the bolt works because of the threads...lots of small radiuses? Needs to be ss for sure.
I think the water4gas cells use the same principle...with the wire electrodes.
That's one of the MAIN PROBLEMS on the hydrogen forums...too many pushing the perfect electrolyzer...instead of just building one and getting some experience? Newbe gets on a forum....lots of confusing info. If you read all the info provided by the various LINKS...your head will be spinning for months....I know.
I think some people don't see results maybe due to the vehicle they install on or the way it's set up...then they go for the most efficient design...or designs that put out mucho gas. The Tero cell is nice...but is technically more difficult.
What's a newbe to do? Got to be able to make or buy one. Need to have room for it. Needs to stay cool. Don't know whether it will work or if you are wasting time and money.
higher Octane = Better MPG JBW General Fuel Topics 9 04-04-2012 12:54 AM
A shot with a mix... GasSavers_SD26 Diesels 23 03-13-2008 06:20 PM
Air scoop for mpg? ZugyNA Experiments, Modifications and DIY 10 12-05-2007 10:40 AM
Brake Puck Return Tool - Home Made Mayhim Experiments, Modifications and DIY 0 11-27-2007 12:33 PM
BIG car Andy-Paul Transmissions and Running Gear 30 10-24-2007 02:25 PM
