Need info on turbines - Fuelly Forums
Old 09-18-2007, 09:00 AM   #1
DRW
How about using the gear drive and pulley off a vortech supercharger? See http://vortechsuperchargers.com/cate...=SUPERCHARGERS
You'd need to fabricate and attach some sort of a turbine (or whatever meets your needs) instead of a compressor section. This also gives you the option of changing pulley sizes for different shaft speeds.
I'm also curious how you're going to get much energy out of 220 degree gasses? Is that in degrees C or F? Exhaust gas temp under typical freeway cruising conditions usually run around 720 to 820*C, so either way you're trying to use a cool, low energy gas.
Dave W.
Concerns coming over from Gas Cubby Johnsons93 Fuelly Web Support and Community News 3 10-31-2013 06:50 AM
Kickstarter - Video Series on Better MPG andyrobo General Fuel Topics 3 03-29-2013 07:49 AM
Mineral Spirits- might not be a good additive diamondlarry General Fuel Topics 10 12-17-2005 02:52 PM
Search feature added Matt Timion Fuelly Web Support and Community News 1 09-26-2005 02:02 PM
I was looking through my crx dealer brochure... bagpipe goatee General Fuel Topics 10 09-04-2005 03:51 PM
