Need info on turbines - Fuelly Forums
Old 09-15-2007, 04:09 PM   #1
trebuchet03's Avatar
Originally Posted by 91CavGT View Post
I need some info on turbines. The ones that are powered by non-flameable gas that can have a pulley connected to it so as to power engine accessories.
I don't want to get too indpeth on this idea as I don't even know if it will work, but if it does then it would mean 10-15 hp gains on most cars and a substantial increase in gas mileage. In short, I need something that can turn a non-flammable gas of approximately 220 degrees into rotational power.
I think I may have found a way to utilize some of the lost energy in a combustion engine!!
So, I'm thinking you mean a centrifugal compressor --> turbo charger.
But the "In short, I need something that can turn a non-flammable gas of approximately 220 degrees into rotational power." Is a bit hard to come by. Turbines typically take pressure and temperature --> generate work and out comes a delta pressure and delta temperature. From a car, you have exhaust gas, and a pressure build up.
So that said, for a turbine, you'll need a pressure build up of some sort. In large operations, it's usually pounds of steam delivered at a certain pressure.
A sterling engine, however, can take a temperature difference and make rotational work
11/12
Concerns coming over from Gas Cubby Johnsons93 Fuelly Web Support and Community News 3 10-31-2013 06:50 AM
Kickstarter - Video Series on Better MPG andyrobo General Fuel Topics 3 03-29-2013 07:49 AM
Mineral Spirits- might not be a good additive diamondlarry General Fuel Topics 10 12-17-2005 02:52 PM
Search feature added Matt Timion Fuelly Web Support and Community News 1 09-26-2005 02:02 PM
I was looking through my crx dealer brochure... bagpipe goatee General Fuel Topics 10 09-04-2005 03:51 PM
