my experience with heated fuel/vapor carb - Page 2 - Fuelly Forums
Old 08-13-2008, 05:52 PM   #11
flapdoodle's Avatar
Originally Posted by soletek View Post
I wonder if breaking up the vapor via sound waves would promote even better results. For example, using a reptile tank mister downstream of the wicking element.
I was wondering the same thing. The misting devices (ceramic disc) are cheap on eBay, but all are 24 volts AC. However, my alternator has a 24 VAC connector for the choke heater. Might be worth investigating.
Old 08-15-2008, 07:49 AM   #12
your car has 24vac ????
COMP is offline   Reply With Quote
Old 08-15-2008, 08:17 AM   #13
I know from reading the service manuals from my Buick that the Regals with the opera lights on the sides had 110vac to power the opera lights. I have no idea why though... seems to me you could have a 12vdc lightbulb do the same thing.
Old 08-15-2008, 08:31 AM   #14
i agree
Old 08-15-2008, 09:09 AM   #15
flapdoodle's Avatar
Yes, not too uncommon to run the choke heaters from an extra tap on the alternator. It comes off the center of the "Y" before the diodes. It is easy to spot because of the shielded wire to prevent radio interference.
That year also had an option for a second alternator that produced 120 VAC for defrosting the gold plated windshield. (not joking). I think it was called the Sierra package. Looking under the hood I can't imagine where the second alternator was installed.
Old 08-15-2008, 09:31 AM   #16
and this is a 1976 towncar ???
Oh is the glass PPG ??
Old 08-15-2008, 09:43 AM   #17
flapdoodle's Avatar
Yes. Tinted even.
It is an oddball. That is why I have kept it. Has disc anti-lock brakes on four wheels among other things. I have checked every 75-76 I have ever seen and this is the only one I have found. Downside is the power steering pump runs the brakes.
Old 08-15-2008, 10:25 AM   #18
Yes. Tinted even.
hydro brakes ,,,,,thanks going to the "yard" to look for ford parts
Old 08-15-2008, 11:00 AM   #19
flapdoodle's Avatar
Back to the topic... does anyone know for sure that the little ceramic disc type misters will work on gasoline? I had no luck running one on distilled water. It required tap water. That makes me suspect that a certain amount of conductivity is required that may not be provided by gasoline.
Old 08-15-2008, 04:56 PM   #20
Strange, they should just be piezo elements like the beepers in the back of watches, but driven by a higher frequency, can't see why distilled water would not work.
For ultrasonics in my cars, I'm putting pits 1mm to 2mm deep done with a 1/16 drill bit at points of high airflow near the injectors. According to helmholtz resonator theory these should resonate in the ultrasonic and potentially break up large fuel droplets.
In a carbed or TBI motor, I'd look at putting them in the area above and below the throttle plate, as this is where flow should be fastest at small throttle openings.
More metric unit options bem Fuelly Web Support and Community News 1 04-23-2011 01:25 PM
Share Data With Friends (Facebook, etc) Saiyaman156 Fuelly Web Support and Community News 4 09-17-2008 09:45 AM
Three Laws of Fuel Economy Ernie Rogers General Fuel Topics 6 05-22-2008 08:08 PM
Getting interested in saving gas phantomcow2 Introduce Yourself - New member Welcome 5 08-04-2007 09:58 PM
New Members! Tell us about yourself! Matt Timion Introduce Yourself - New member Welcome 7 06-01-2007 06:51 AM
