Mirror removal - 2008 Hyundai Accent - Page 3 - Fuelly Forums
Old 06-03-2009, 12:35 PM   #21
After a lot of searching, I found this clip. Totally worthless to me since it can rotate. I searched McMaster Carr and Grainger under "clip", "mount", "fastener", "quick release", "slide", "rail", and "bayonet". Nothing quite right, but a couple sheet metal things that aren't tight enough to do the job.
Anyhow, I think I could just leave a couple pan head bolts exposed (slightly above the surface and painted black), and then make a plate shaped like an E, but rotated to have the fingers of the E pointing down. The spaces in the E would slide under the exposed bolt heads. Pretty easy to whip up. I hope that's at all clear. I do have a dovetail cutter, but that'd require thicker stock and more work.
co de pen den cy
Function: noun
Date: 1979
Old 06-03-2009, 12:59 PM   #22
No need to create that mount. It already exists, and could work. Remember wall-mounted telephones?
Old 06-03-2009, 01:08 PM   #23
I'll check some of them out. I can use the female side maybe. With coupling nuts I can attach the protruding bolts right to the car's metal structure, which is cool.
co de pen den cy
Function: noun
Date: 1979
Old 06-04-2009, 01:58 AM   #24
Figure I should determine the mirror before designing the mount. I was thinking bicycle mirrors because they're light, cheap, and compact to stow in the trunk. Also, I think they'll be easier to work with than going with ones from a junkyard. Should've looked for some when I was at Walmart.
co de pen den cy
Function: noun
Date: 1979
Old 06-04-2009, 06:31 AM   #25
Go back to Walmart. They have a mirror that should work and it's cheap.
Old 06-04-2009, 06:43 AM   #26
When I was there I couldn't find any car mirrors and when I asked they told me they only carried blind spot mirrors now.
co de pen den cy
Function: noun
Date: 1979
Old 06-04-2009, 06:46 AM   #27
Oh, and interior mirrors (rear view and the like).
co de pen den cy
Function: noun
Date: 1979
Old 06-20-2009, 03:58 PM   #28
Just won two bicycle mirrors for $2 on Ebay. They don't have the handle bar mounting hardware, but that's irrelevant.
co de pen den cy
Function: noun
Date: 1979
How much does alignment affect FE? Philip1 General Fuel Topics 7 07-05-2008 10:02 AM
The Petroleum Industry Earnings In Perspective Mayhim Automotive News, Articles and Products 30 04-03-2008 04:26 AM
How The Easiest Hybrid Diy Could Be Done... trautotuning Hybrid Vehicles 20 01-31-2008 02:55 PM
Going up to you guys first: My Metro is for sale!! BumblingB For Sale 4 06-05-2007 05:52 PM
I am new and like the site alata2 Introduce Yourself - New member Welcome 3 05-29-2007 06:16 PM
