MID Install - Page 4 - Fuelly Forums
Old 05-26-2007, 05:00 PM   #31
Send a message via AIM to crabbyman
Cool! Thanks! ..that is mainly what I was worried about. I found the site to build it yourself...but 1.) I am a beginner in designing and building circuits..and 2.) I cant read Japanese!
crabbyman is offline   Reply With Quote
Old 06-03-2007, 07:48 PM   #32
How does the SuperMID compare to the ScanGauge in accuracy? Should it be more accurate considering that it is directly calculating values from the injectors rather than gathering data from a serial data stream?
parasonic is offline   Reply With Quote
Old 06-03-2007, 07:51 PM   #33
Old 06-04-2007, 11:27 AM   #34
There are some limitations on the ScanGauge.
Following is good review article about it...
http://www.cleanmpg.com/forums/revie...e-ii-4495.html
"Another issue has to do with Fuel Cut. The ScanGauge II has no way to tell if the ICE is in Fuel Cut or if the car is at speed running at idle as you would in a NICE-On. Although the FE calculated and shown is very high under this condition (between 130 and 250 MPG depending on speed and ICE size), fuel is still shown being consumed when it is not thus causing an ever increasing error to build in."
My SuperMID can easily be calibrated within about 1% accuracy.
http://www.greenhybrid.com/discuss/s...9&postcount=79
http://www.greenhybrid.com/discuss/s...&postcount=100
Anyone knows how accurate the ScanGauge is?
Yoshi, aka Ken@Japan/ken1784
GasSavers_Yoshi is offline   Reply With Quote
which car saves more gas? civic94 General Fuel Topics 4 08-03-2007 08:55 PM
is grill blocking safe? heyheyhey General Fuel Topics 5 06-22-2007 06:44 PM
The tricks up my sleeve... Methods I may implement for better FE. DrivenByNothing General Fuel Topics 59 04-25-2007 10:40 AM
2008 Prius zpiloto General Fuel Topics 4 01-21-2007 01:31 PM
Users now able to create articles Matt Timion Fuelly Web Support and Community News 0 10-01-2005 02:12 PM
