MID Install - Page 2 - Fuelly Forums
Old 10-09-2006, 03:47 PM   #11
Fantastic! I think I got it. The picture put me over the top and I double checked the counting as well. Thanks a ton Matt and Ben.
The harness with the brown INJ1 cable pulled out on the left and the yellow/blue VSS cable pulled out on the right.
The wires from the SuperMID interface box spliced into the INJ1 and VSS cables.
The ECU put back in place with the interface box velcroed onto it.
Sean88 is offline   Reply With Quote
Old 10-09-2006, 04:07 PM   #12
Matt Timion's Avatar
that's nice and clean.
Old 03-02-2007, 10:05 AM   #13
UfoTofU's Avatar
I have a mechanical VSS on my 88 CRX.
Will I be able to install it and have it work properly or will I have to upgrade to an electronic VSS and swap out my gauge cluster as well?
- UfoTofU
UfoTofU is offline   Reply With Quote
Old 03-02-2007, 10:12 AM   #14
Old 03-02-2007, 11:04 AM   #15
UfoTofU's Avatar
Dang!
What car would I be able to get an electronic VSS out of as well as the gauge cluster?
- UfoTofU
Old 03-02-2007, 11:09 AM   #16
94-01 integra and 92-00 civic for easy cluster swaps
92-00 civic d series for the vss
My vss is out of the cx transmission I sold burnett and the cluster is from a 97 integra,
Old 03-02-2007, 11:22 AM   #17
I have a spare electronic VSS in my office somewhere if you want it.
Old 03-02-2007, 02:11 PM   #18
UfoTofU's Avatar
I'll definitely take that! Let me know what shipping and such will be.
- UfoTofU
Old 03-02-2007, 02:23 PM   #19
Just FYI... I never did test this, but it might be worth testing before you go changing VSS and clusters.
on the back of the cluster there is a terminal that gives an electronic signal relative to your speed. It gives it in pulses, I believe 4 per revolution.
Many people have said it wouldn't work for a SuperMID, but none of them have tested it. It was my original intention to test it before I bought the Honda Fit.
I would test this before going crazy with everything else.
That being said, I don't think that the SuperMID can work on a DPFI engine/ECU. It assumes four injectors. DPFI has one primary injector and one secondary injector.
Old 03-02-2007, 02:37 PM   #20
UfoTofU's Avatar
Would I be able to use my current gauge cluster cover if I found one of these or would I have to get that separate as well?
- UfoTofU
which car saves more gas? civic94 General Fuel Topics 4 08-03-2007 08:55 PM
is grill blocking safe? heyheyhey General Fuel Topics 5 06-22-2007 06:44 PM
The tricks up my sleeve... Methods I may implement for better FE. DrivenByNothing General Fuel Topics 59 04-25-2007 10:40 AM
2008 Prius zpiloto General Fuel Topics 4 01-21-2007 01:31 PM
Users now able to create articles Matt Timion Fuelly Web Support and Community News 0 10-01-2005 02:12 PM
