Lawn Mower Fuel Brand Experiment - Page 4 - Fuelly Forums
Old 03-19-2006, 12:50 PM   #31
00:00.00
yeah this gasoline has been "effecting" me...
look now...
see if that makes more sense...
-unknown
Old 03-19-2006, 12:59 PM   #32
krousdb's Avatar
ok, three runs, average 1322
ok, three runs, average 1322 seconds +/- 1.1%. Very nice. Should prove as a good basis for comparison. Compaq says Shell is the best. If so, it should get worse from here.
Old 03-19-2006, 01:03 PM   #33
It should yes. And man I
It should yes.
And man I can't take it, I'm doing a warm-up run right now, I am going to test acetone and coleman fuel together with the rest of this Shell fuel I have. I may not come up with three 200ml runs, but I just wanna see what it does.
-unknown
Old 03-19-2006, 01:08 PM   #34
zpiloto's Avatar
Longer run time
The run times are quite a bit longer than the first attempt. Do you think this is because of the accuracy of measuring or the 10 degree increase in temperature? If it temp, thats a new factor to look at. I think CITGO will give the longest run time.
Old 03-19-2006, 01:14 PM   #35
krousdb's Avatar
Im thinking by adding
Im thinking by adding acetone and coleman, you are changing two variables. Can you do one run with each?
Old 03-19-2006, 01:28 PM   #36
how about...
Yes they are but its too early to even start guessimating.
Okay I will do one test with every combo. I have enough fuel. One with acetone, one with coleman, one with both. We've been graced with seriously calm weather, I had to take advantage!
-unknown
Old 03-19-2006, 01:52 PM   #37
Compaq888's Avatar
this is weird. Mobil runs
this is weird. Mobil runs longer than Shell, really weird.
Old 03-19-2006, 02:38 PM   #38
krousdb's Avatar
Re: this is weird. Mobil runs
I think all of the tests so far have been Shell. Mobil is next. I'm betting no significant difference between any brand, except for Sunoco. IIRC, Sunoco uses 5 or 10% Ethanol. At least that is what is shown on the pump in my town. If so, I expect it to run 21 - 21.5 minutes.
Old 03-19-2006, 02:55 PM   #39
Compaq888's Avatar
you're right. He just made the test better.
Old 03-19-2006, 03:03 PM   #40
Shell + Coleman + Acetone results:[1324.46 sec average]
Damn. I truly did not think things would get so close. No more rounding up...
The constants in this round are:
-Three 200ml runs (warm runs)
-Barometric Pressure remained statisticly constant at 29.33in - 29.35in
-Measurable windspeed stays between 2.5mph and 1.6mph
-Same Shell gasoline
-15 minutes between runs to restart.
Run #1 Coleman&Acetone
-Length: 22:05.00 minutes
-Temp remained within 48°F
-Humidity was 33% - 34%
Run #2 Coleman Fuel alone
-Length: 22:03.94 minutes
-Temp is exactly 49°F throughout
-Humidity: 32%
Run #3 Acetone only
-Length: 22:04.43 minutes
-Temp spread is 48.5°F - 49.2°F
-Humidity: 32%
Interesting.
-unknown
