Isopropyl Alcohol - Page 6 - Fuelly Forums
Old 07-04-2008, 05:32 AM   #51
Originally Posted by RoadWarrior View Post
MMOil is basically mineral spirits, white gas, and trichloromethane/ethane (or similar)...
So, varsol, coleman fuel and typists correction fluid thinner (Used to be that, haven't checked lately)
Seafoam is like varsol and isopropyl.
I dunno when people are gonna start believing me and just start using generic varsol, isopropyl and kerosene to clear crap out the motor instead of buying all this overpriced crap.
Edit: Hmmm yeah, dunno if anyone noticed, but practically NONE of the constituents of MMO have any significant lubricating abilities.
i haven't seen vaesol for sale ,,where you get it ?
COMP is offline   Reply With Quote
Old 07-04-2008, 05:41 AM   #52
It's the brand name mineral spirits, brush cleaner, paint thinner kind of stuff. Mineral spirits will do, find it at hardware and paint stores.
Old 07-04-2008, 05:49 AM   #53
Oh,,, i have a mix using that
Old 07-04-2008, 05:49 AM   #54
Originally Posted by COMP View Post
Ok ,,i think there is a difference i know ATF doesn't work as good in my air tools
You've put ATF in your air tools?
They're not buying varsol, isopropyl, and kerosene. They're buying marketing, packaging, and convenience, just like someone buying a $160 ScanGauge II instead of a $30 ELM327 to use with a salvaged laptop. It's well worth it for most people and there's nothing wrong with that.
Old 07-04-2008, 05:53 AM   #55
yes i have ,,,2-3 drops
Old 07-08-2008, 05:08 PM   #56
ZugyNA's Avatar
I put 3 oz MMoil in with 10 oz acetone...shook it...then found that 1 of the 3 oz of MMoil was not left in the bottom layer. This tells me that 2/3s of MMoil is an oil...the rest is a solvent that blends with acetone.
I use MMoil not because it is a magic elixor...but because it is convenient for testing...I'd also use mineral oil (baby oil)...2 cycle oil...ATF??....maybe even vegetable oil...where it would act as both a fuel and as a lube.
Old 07-11-2008, 06:25 AM   #57
Originally Posted by joeventura View Post
Well in the interest of research I just added 3.4 oz of 91% isopropyl alcohol and 0.7 oz of Marvel Mystery Oil to a 17.8 gallon tank of gas unleaded.
Since I am super anal about stats of my last 7 or 8 tankfuls, if there is even a 5% improvement I will know and report it here.
I drive back and forth to work the same way everyday with little change.
Just a small request from some of you veterans of this website, as you will read in the message above, no abbreviations, no shorthand, etc.
MMoil means nothing to folks you are new here, take the extra 5 seconds required to be clear and everyone will appreciate it.
Thanks in advance!
P.S. ATF=Automatic Transmission Fluid
The addition of the above resulted in zero increase (actually 0.5 mpg decrease) but such a small change could be the result of almost anything but surely did not result in any measurable positive change.
joeventura is offline   Reply With Quote
Old 07-13-2008, 04:45 AM   #58
ZugyNA's Avatar
As mentioned (?) I'm currently testing iso/MMoil in an EFI....no results yet.
Very possible that the iso will work best with a carbed engine that might be running a little rich?
Old 07-24-2008, 06:42 PM   #59
You could, but you have to look
Isopropyl or "rubbing" alcohol can be used as a cleansing additive, however, isopropyl alcohol is sold in stores usually being 70% or 91% alcohol with the remaining part water. You don't want water in your system, but i am sure a racing fuel retailer would sell it 99.99% pure (the highest you can get). Also, it might bring down your FE due to the fact that alcohol contains less energy per gallon than gasoline, but with the small amount you would be using, I wouldn't see a problem there. By the way, you will often read or hear about drivers who say their FE decreases with the use of E10/E85, including me. Lol
hound_13 is offline   Reply With Quote
Old 07-24-2008, 06:54 PM   #60
You can get fairly pure IPA at hardware stores in the paint thinner section.
Average km or miles per day... ChAnDeRu Fuelly Web Support and Community News 2 04-21-2010 01:11 AM
Consumption units question cvzyl Fuelly Web Support and Community News 5 09-22-2009 04:34 AM
CAFE standards negate high FE vehicles northboundtrain General Fuel Topics 11 07-07-2007 04:22 PM
Ecotek CB-26P GasSavers_Red General Fuel Topics 6 07-06-2007 12:08 PM
Brit & European Car Day, Apr 29,2007, Dallas TX bzipitidoo General Fuel Topics 3 06-03-2007 08:05 PM
