Is there any way to get Manifold pressure reading in and OBD 2 auto? - Fuelly Forums
Old 01-29-2010, 02:54 AM   #1
eee
eee's Avatar
Question Is there any way to get Manifold pressure reading in and OBD 2 auto?
Is there any way to get Manifold pressure reading in and OBD 2 auto? perhaps directly from an already existing sensor? or perhaps by installing and aftermarket gauge? What's the quickest cheapest way to make or install a gauge yourself? my car is a 95 scoobie with obd 2.
eee is offline   Reply With Quote
Old 01-29-2010, 04:10 AM   #2
Intake manifold or exhaust manifold??
If intake, a simple vacuum gauge will do wonders, just t-off any existing vacuum line. These gauges are like $15 at most places. It'll show vac and pressure
Google search for "vacuum gauge"
John
'09 Saturn Aura 2.4L
'96 Chevy C1500 (5.0L 5sp)
'01 KTM Duke 2
Old 01-30-2010, 06:11 PM   #3
imzjustplayin's Avatar
well if the car comes with a map sensor, then a scan gauge should be able to pick up on that.
Old 02-28-2010, 03:35 PM   #4
eee
eee's Avatar
well, so, i found that the legacy has a vacuum sensor mounted by the wheel column, but having poked under the hood for quite some time it seems not so for the impreza 1.8L engine. it must be mounted somewhere else. following the tubing from the manifold, i think i found one 2 wire sensor, but couldn't read any voltage off that; i believe that was the knock sensor. the vacuum sensor must be better hidden somewhere on the impreza; anyone found it on this car?
Old 02-28-2010, 08:06 PM   #5
GasSavers_JoeBob's Avatar
This may help...http://www.fixya.com/cars/t3140741-map_sensor
