Is HHO the way to go? - Fuelly Forums
Old 01-08-2008, 09:02 AM   #1
I saw the add for Water 4 Gas here and decided to check it out. Well I must say I'm impressed, I have been told by so many in industry that cracking hydrogen from water takes more energy to make than the gas that is produced that I wrote off the idea of hydrogen along with the fuel cell revolution. There have been so many Nay Sayers going, the infrastructure of America cannot support broad use of hydrogen and prodution, that I thought hydrogen was just another idea that was researched, tested, and found to be a failure. Incedentially the nay sayers being large companies I'v researched in my quest for greener living. A hobby of stock research and futures on energies, broad range HHO production is said to be too expensive.
Well I was wrong, its seems as easy as a revolution of backyard mechanics putting together small jar HHO generators to double the mileage of there cars was a reality. So I have been combing the net looking for all sorts of info on HHO and the best source I found was Youtube, just enter HHO or MPG in a search and you will be treated to thousands of video's by home experimenters making HHO for pennies. Also Water 4 Gas has great schematics for building HHO generators for cheap.
HHO, Hydrogen/Oxygen is simply made by making a sandwich of stainless steel plates in a bath of baking soda and water. Use the 12 volts from your car battery to start the electrolisis process in the plates and viola, you can suppliment your gasoline with a stream of HHO.
The benefits, in a fuel injected car, the O2 sensor will read a rich condition and lean the mix, your burning less gasoline getting better mileage and it only costs you water and baking soda.
So as soon as I buy my next car ( Saturn, Civic, Escort, or Geo), I'll start building some cells and see how much HHO I can make.
Has anyone out there had any luck assembling cells and does the mileage double? From the info on Youtube, it seems the skys the limit. Oh also, if you do build a system, make sure you install back fire valves, so you don't have a Hindenburg under the hood.
Oh, MPG Research has started a column on Hydrogen, this seems to be the fuel of the future, I can't wait to hear the responce. Thank you.
