Well after thinking about it for way to long I finally wired in the LC-1 wide band controller that can simulate a narrow band O2 sensor. I ran a ground to the bolt on the bellhousing that has may other grounds on it.
http://www.innovatemotorsports.com/
I ran it a couple days at the 14.7 A/F ratio. I hooked a computer up and tried to lean it out a bit. I thought it appeared to program. I drove the car and it just kept getting leaner until it barely ran. I managed to get home but the car was missing and the catalytic converter may have been damaged
I tried repeatedly to get the controller to reset to factory defaults and re-calibrated the sensor. I finally put the OEM O2 sensor back in. It took over 30 miles to trim back to running decent. I lost a little over 2 mpg off a 600 mile tank with this episode. I was only making about 45 mpg when it was running too lean. Probably the scangauge could not be trusted in these conditions though.
There is a bit of discussion of people having problems with these on the Forum at the Innovate web site. The problems are usually resolved. As you may know my under hood temps run a bit high but I don't think that was the problem, well maybe.
As the engine gradually came back in to trim I could experiment with the way it ran. I am convinced that there is almost no additional leaning that can be done to my Saturn if it is running IAT over 160 F.
It was apparent from the way my head and spark plugs looked that it was already running reasonably lean.
I might have a slightly used LC-1 for sale soon. There are other things I would rather do than mess with this. The little Saturns get over 40 mpg out of the box. I think the factory did a pretty decent job of programming it already and I don't think I am going to gain much pursuing this line.
I need to think about it a few days and maybe take another shot at it. I posted a PO432 code once. I don't want to ruin a good catalytic converter for no good reason. I posted no codes today and did not have that odd periodic combustion in the exhaust system anymore but I need to keep my fingers crossed. Even when the engine had trimmed back far enough that it was not missing but was still running lean it would get an intermittent pulse of combustion in the exhaust system.
Well that is today's story. I might change it a bit tomorrow.
