ICE loads - Fuelly Forums
Old 11-10-2007, 05:57 PM   #1
basjoos's Avatar
ICE loads
When I got home from a recent trip, I tried adding various electrical loads to the engine while monitoring the pulse width displayed on the SuperMID. Below are the results.
Warm idle with nothing turned on........2.3 to 2.4
Parking lights on..............................2.4
parking and headlights on..................2.6 (high or low beam)
Brakes on.......................................2.4
Fan on lowest speed (level 1)............2.4
Fan on next higher speed (level 2)......2.4
Fan on level 3.................................2.4 to 2.5
Fan at max speed (level 4)................2.5
A/C and fan at level 2......................3.6
A/C and fan at level 4......................3.7
ICE cooling fan on...........................2.4
Radio on low...................................2.3
I also monitored the pulse width for the 1st minute of idle when starting a cold engine at 55F ambient temp.
Start idle.........4.2
After 30 sec.....2.9
After 1 min.......2.6
aerocivic.com
Old 11-10-2007, 06:57 PM   #2
GasSavers_TomO's Avatar
Thanks for posting your info, basjoos. It gives me an idea of what settings I can run on my climate control this winter and still keep things relatively low consumption.
Honda Civic VX Info/Links
Old 11-10-2007, 08:40 PM   #3
1993CivicVX's Avatar
sounds like cycle A/C on fan 4 is better than leaving it on on fan 1 or 2.
three stripes the charm!
Old 11-11-2007, 12:27 AM   #4
Team GasMisers5!
landspeed's Avatar
To add to this... I'm sure modern ECUs don't do this, but... my ECU actually enriched the fuel mixture a little bit when electrical loads were present - even if you were, for example, going uphill at 50. This would be 0.1 e.g 15.0 down to 14.9, and I think it was unintentional as well. Just something to think about
P.S. the Pulse widths from cold are just like mine (2.3 when warmed up, 4.8 when starting for the first few seconds, quickly dropping to about 3.4, then slowly towards 2.3).
Hypomiler
Old 11-11-2007, 12:51 AM   #5
cfg83's Avatar
1993CivicVX -
Yeah, that supports that theory that the level of AC doesn't matter. The compressor is drawing the same load regardless of the setting.
But ... aren't some of today's AC units "variable load"?!??
Old 11-11-2007, 01:05 AM   #6
cfg83's Avatar
basjoos -
This makes me feel even better about my Fan Radiator Switch. I use it to manually cool off the radiator coolant temp when I am stuck in traffic. You're results for the "ICE cooling fan on" are very reassuring .
Old 11-11-2007, 07:48 AM   #7
At least for the heater, on all of my cars I can simply turn the knob to heat and leave the fan off, and heat comes out of the vents as I drive naturally.
It may not be the best when it's really cold outside, but it works.
Old 11-11-2007, 06:07 PM   #8
basjoos's Avatar
Originally Posted by cfg83 View Post
1993CivicVX -
It didn't show up on my test because I didn't run it long enough , but there is a savings at the lower fan speeds if I let it run longer. After a few minutes at level 1 or 2, the compressor will cycle off for a period of time, then kick on again for a period of time, and repeat. At levels 3 and 4 the compressor is on full time on the usual summer day where I might be tempted to use the A/C. There is a temp sensor of the evaporator coil that cuts off the compressor when the cold reaches a certain minimum temp.
aerocivic.com
Old 11-11-2007, 06:53 PM   #9
wow, i never thought about my stereo making me get worse mpg. i have 2 12's with an 800w amp. if i could go without the bass for any period of time, id disconnect it to see how my mileage improves.
not to mention the box weighs probably 80 lbs.
ezeedee is offline   Reply With Quote
Old 11-11-2007, 08:32 PM   #10
cwa
Thank you Basjoos. It is very useful. I just got a Supermid and then I tried to do that one my Car (1.3L, Auto) I got very similar readings.
I also tried the same thing when the Car is D (Still with Break), it comes with additional 1.1 pulse width. (Meaning Stop reading is 3.5, with Ac $.8-5.1) etc.
REgards
CWA
cwa is offline   Reply With Quote
MPG versus air temperature and Altitude MensaMike General Fuel Topics 6 06-21-2011 05:16 AM
Fell off the wagon this morning - major hangover ma4t General Fuel Topics 22 06-19-2007 03:45 AM
The agony of the diesel Sludgy Diesels 19 04-18-2007 03:41 AM
Just failed emissions twice Matt Timion General Maintenance and Repair 84 07-27-2006 02:19 PM
Probably a Silly idea, but.... krousdb General Fuel Topics 8 03-26-2006 08:10 PM
