How to use heli-coils to fix your stripped bolt holes - Fuelly Forums
Old 01-18-2006, 06:57 PM   #1
Matt Timion's Avatar
<p>A bolt hole on my engine block is stripped. I actually imagine that all of them have something wrong since the bolts are rusted and the head is leaking oil at the head gasket. i've decided to tackle this with heli-coils. </p>
<p>Below is a write-up I found on the internet describing how to do this.</p>
<p>Taken from :<a href="http://www.roadstarmagazine.com/modules.php?name=News&amp;file=article&amp;sid=233 ">http://www.roadstarmagazine.c....=233</a></p>
<p>---</p>
<a href="http://www.roadstarmagazine.com/images/techimages/helicoil1.jpg" target="_blank"><img border="0" src="http://www.roadstarmagazine.com/images/techimages/helicoil1sm.jpg" align="left" alt="Helicoil Kit" width="120" height="114"></a></a>Everyone has had it, that heart stopping moment when you think you have stripped out a thread and your wondering to yourself, "What the hell do I do now?" For me it was the thread on the sub-frame for one of the four bolts that hold the rear fender in place, I stripped that puppy good. Because of this I was looking down the barrel of well over a $100 for a second hand sub-frame or who knows how much for a new one! But thankfully that was when I remembered hearing about helicoil kits. Read on, if you will, as it might just save you a LOT of money someday and no end of anguish.
<br>
<br>Experienced wrenches and even some home tinkerers will be familiar with helicoils, and if you are then you have probably had to use them in the application they were design for, which is creating a new thread for your bolts to grip onto. If you haven't heard of them then this article attempts to show you how <strong>easy</strong> they are to use and how they can save you a lot of money. To give you the short version, a helicoil kit will allow you to drill out a stripped bolt hole, tap a new thread into the larger hole, where you then wind in the helicoil, that in turn becomes the new "thread" for your bolts. Helicoils are also typically stronger than the metal you are putting them into, so chances of stripping out the thread again are just about zilch.</p>
<p>Basically a helicoil kit usually consists of a number of helicoils (duh), thread tapper and a couple of tools to put the kit in. Sometimes they will include the drill bit that you need, but you may have to buy it separately. If you do have to buy the drill bit separately make sure you buy EXACTLY the size that your kit requires, one measurement too big or too small and it is useless. Oh and be sure to buy a drill bit that is for drilling metal, don't try and save money on a wood drill bit, it just isn't worth it. </p>
<p><a href="http://www.roadstarmagazine.com/images/techimages/helicoil2.jpg" target="_blank">
<img border="0" src="http://www.roadstarmagazine.com/images/techimages/helicoil2sm.jpg" align="right" alt="Helicoil Kit" width="131" height="126"></a>Now I'd had problems in the past when a misaligned bolt stripped <i>some</i> of the thread of my fender sub-frame (because I like to swap between solo and two-up a lot) although I was able to save it at the time just by re-tapping the hole. It was when I was putting on a new set of saddle bags that I stripped out the hole completely and the weight of the bags (Tour Classics) meant I had to fix the problem without delay. For the record, the size helicoil kit I used was <strong>M8-1.25</strong> (matches the bolt type for that area) and the drill to match this kit is a <strong>21/64 hi speed bit</strong>.<strong> </strong>If the drill bit isn't included in the kit and the size required isn't written anywhere then ASK which one you need, don't ASSUME!</p>
<p><a href="http://www.roadstarmagazine.com/images/techimages/helicoil3.jpg" target="_blank">
<img border="0" src="http://www.roadstarmagazine.com/images/techimages/helicoil3sm.jpg" align="left" alt="Helicoil Kit" width="131" height="126"></a>So the first thing you have to do is to drill out the hole, just make sure you have the drill as straight as possible. The drill bit for my kit was <strong>21/64 </strong>in size so it left me with a perfectly flush hole with no sign of the old thread. Thankfully I was able to leave my fender in place for the job as it meant less stuffing around.</p>
<p><a href="http://www.roadstarmagazine.com/images/techimages/helicoil4.jpg" target="_blank"><img border="0" src="http://www.roadstarmagazine.com/images/techimages/helicoil4sm.jpg" align="right" alt="Helicoil Kit" width="131" height="116"></a>Next you have to tap a new thread using the tap that comes with the kit. The tap is tapered at the front end to help you get the thread started and using a shifter you wind it through the hole. Make sure you wind it all the way through until you stop feeling "resistance" as this means the hole is now completely tapped with the new thread. Gently wind out the tap with the shifter and when you do you shouldn't feel any resistance, in fact you may even be able to twist it out with your fingers.</p>
<p>Now you get one of the helicoils and using the tool supplied you wind it into the new thread until it is flush with the frame (sorry no picture). You also shouldn't feel any resistance as you do this but if you do you may just need to clean the thread up a little. It is also at this point why the drill bit size is so important, as the outer thread of the helicoil will match the newly tapped hole, the inner thread of the helicoil will match your bolt size. </p>
<p><a href="http://www.roadstarmagazine.com/images/techimages/helicoil5.jpg" target="_blank"><img border="0" src="http://www.roadstarmagazine.com/images/techimages/helicoil5sm.jpg" align="left" alt="Helicoil Kit" width="131" height="136"></a>One the coil is in place you use the little punch that should come with the kit to knock the little tang off the end of the helicoil that assisted with winding it in. Don't try to twist this off (unless the instructions say to) as you may warp the helicoil and you don't want to do that.</p>
<p>And now your finished so all that is left is to put the bike back together! Because it was so simple I decided to drill out the other three holes in my sub-frame and put helicoils in all of them. As mentioned earlier the helicoils are usually a lot stronger than the metal they are put into so hopefully I am going to avoid the problem happening again down the road.</p>
<p>Hopefully this write-up will make you more confident in using a helicoil kit if you are ever unfortunate enough to need to utilise one.</p><p align=right><strong>March 2004<br>RoadStarMagazine.com
</font>
Old 01-18-2006, 08:33 PM   #2
Another
Another resource:
http://www.atvconnection.com/editor/techtips/techtip13.htm
