How to build a conversion harness for a Honda VX (p07) ECU - Fuelly Forums
Old 01-02-2006, 11:39 AM   #1
Matt Timion's Avatar
<style type="text/css">
.style1 {
color: 1;
font-weight: bold;
.style2 {color: 1}
</style>
<p>This is for the people who want to put a Honda Civic VX Engine/ECU into their obd0 Civic/CRX (1988-1991). This writeup is assuming you are using a MPFI ECU/wiring harness. This comes standard on the Civic EX, the CRX Si, and the CRX HF. If you have a Civic STD, LX, DX, or a CRX DX you need to convert to MPFI before this harness will work. There are plenty of write ups on the internet on how to switch from DPFI to MPFI.</p>
<p><strong>What you need:</strong> You will need the female plugs from an obd0 ECU. I recommend going to the junkyard and finding a pm5 ECU from a Civic DX or LX. Rip out the female plugs from the ECU and desolder the connections. You will also need the male plugs from a obd1 civic. ANything made between the years of 92-95 will do, but might require a little modification. If you are lucky and can find yourself a Civic VX in the junkyard I'd recommend taking the ECU plugs from it as the wires are all there.</p>
<p>Assuming this is all true, make a conversion harness using the pinouts below:<br>
<table width="100%" border="1">
<tr>
<td> It seems that some of the pinouts were incorrect. I just ordered a conversion harness from a company that specializes in them. I will reverse engineer the pinouts and upload them here at a later date. </td>
</tr>
</table>
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 07:48 AM
Problem with badges. DTMAce Fuelly Web Support and Community News 4 04-06-2011 12:54 AM
Help...MPG calculator not working djquik1 Fuelly Web Support and Community News 1 10-18-2010 04:57 AM
Solar/plug-in 12V system, alternator optional MetroMPG Experiments, Modifications and DIY 10 09-20-2006 05:51 PM
DIY: Valve Cover Painting SVOboy Experiments, Modifications and DIY 7 05-20-2006 11:24 PM
