How does ignition timing change affect MPG - Fuelly Forums
Old 02-15-2011, 06:45 PM   #1
gto78's Avatar
I'm very limited to what changes I can make to my Expedition with my programmer. My question right now is whether advancing the ignition timing will help or hurt MPG. If it's advanced then power will go up, but then again if I'm driving as easily on the accelerator as possible then does it really help? And if the spark occurs closer to TDC then although the compression in the chamber will be less, the fuel will be burned for a longer period of time after TDC. I'm thinking that if I'm driving extremely lightly like I have been than retarding the timing may help MPG? Or is the ultimate goal to make the absolute most pressure in the combustion chamber without detonation (advanced timing)?
gto78 is offline   Reply With Quote
Old 02-16-2011, 05:02 AM   #2
GasSavers_Erik's Avatar
Re: How does ignition timing change affect MPG
Advancing timing as much as possible without pinging will give the best mileage. You might just advance it 1-2 degrees at a time because it is possible that if pinging occurs, the knock sensor will detect it before you hear it and the ECU would then retard the timing and richen the mix. In this event you might be worse off than if you would have just left the timing alone.
So, IMO you should advance it 1-2 degrees at a time and run it for a few tanks and compare the mpg to what you were getting at the factory recommended timing setting.
Old 08-03-2012, 05:56 AM   #3
kamesama980's Avatar
Might change but I doubt it'll be measurable. I've done it on several cars with adjustable distributors. Never tried retarding timing but advancing up to the point of knock hasn't shown any quantifiable gains. what I mean by that is while there *seemed* to be a slight inprovement in FE before/after, it was less than the deviation between tanks.
power change was indeed noticeable though. not a lot but definitely there.
-Russell
Old 01-14-2017, 01:45 PM   #4
advancing the timing increases torque and moves the torque peak to a lower RPM this will increase mph. advance the timing to the point of pinging then back it down a bit. this can be done without a timing light. if your car has mechanical advance (under the dist cap you will see metal weights held with springs) you can put weaker springs in place of the stock ones this will allow your timing to advance when you drive faster when the load is lighter
58DeSoto is offline   Reply With Quote
Could you add? blackfive Fuelly Web Support and Community News 2 01-11-2011 07:07 PM
Ability to comment on Fuel Tips randomic Fuelly Web Support and Community News 4 08-21-2008 11:25 PM
Aerodynamics improvement Greybrick General Fuel Topics 0 04-10-2008 07:14 AM
