Home built ramps from 2x10's? - Page 2 - Fuelly Forums
Old 04-16-2007, 08:21 PM   #11
DracoFelis's Avatar
Originally Posted by Bill in Houston View Post
I like my Rhino Ramps a lot.
Unless you really want to "recycle", by making your own ramps, I also 2nd the suggestion of Rhino Ramps. While I don't use them often (mostly because I usually let my mechanic to car work, instead of doing it myself), they have worked great on those few occasions when I've tried them. And they were reasonably cheap to buy (if memory serves, my pair cost me around $40 at Walmart), for a pair of ramps that are made out of really STRONG plastic!
BTW: I got the 12,000lb set, not because I needed that much weight, but because they were wider (and therefore easier to drive up on) than the (slightly cheaper) 8,000lb set.
Old 04-17-2007, 02:26 AM   #12
We have some ruff planed 3x10 ramps sinve I was a kid. They work great beveled the end so they don't move driving up. They feel a lot better on bare hands on a cold day and don't rust or make as much noise when dropped. Then can be raised up more or less with bricks too.
Old 05-11-2007, 06:32 PM   #13
Originally Posted by omgwtfbyobbq View Post
My cousin has a pile of scrap wood 30ft high at his house that'd be perfect for this project.
You could build ramps to get the car on the roof of the house, LOL!
Old 06-08-2007, 11:26 AM   #14
well i did the ramp and its heavy as ****.....lol but my car is like 2 inches off the ground so taht why the ramp was needed, i couldnt even get a jack under it i had to drive the car on the ramp then jack it up.....lol
GasSavers_silvergt is offline   Reply With Quote
Old 06-10-2007, 08:01 AM   #15
Snax's Avatar
That's the same reason I built my ramps. My last car was was too low to even get a low profile floor jack properly underneath. I built my ramps out of 2x6s three layers deep. It's not much of a lift, but at least at that point I could get a jack under the car!
Anyway, the middle layer is composed of three seperate blocks of 2x6 with about 8" spaces between them to lighten the ramp and provide carrying handles.
Obviously 6" is a bit narrow, but it has not presented much of a problem in how I have used them.
LiberalImage.com
I think, therefore I doubt.
Old 06-10-2007, 08:44 AM   #16
my dad and i built somehting like that but we attached our steel stor bought ramp sto the end of the wood ramp. raises the wheels a foot off the ground.
Old 08-01-2007, 05:40 AM   #17
Yeah we've always had these pretty giant 4"x1'x2' cement blocks that we stacked in a way to make a 'ramp' and then filled the 4" rise with 2x4 scraps to get up each step. Worked well.
Maybe I should build something like this for my house. My driveway is already 4" up so I could just extend off of that.
Old 08-01-2007, 06:53 AM   #18
brucepick's Avatar
I did a "quickie" version that worked out well.
Discovered I had 2 - 2x10's on hand.
Cut two pieces 19" long, the other two about 36" long.
Two of the cuts I did at an angle so there's a bevelled surface for the tire to go up.
Just lay them down on top of each other and that's all.
When I get time I'll cut another pair for more height.
Lower "steps" can be 11-12 inches long, no problem.
(that is, 11" plus the part that's below the layer above it)
Top step should be longer (that's my 19 inchers) so you don't roll off the end when going up.
Leaving it as separate boards makes them easy to carry. Make some marks so it's easier to line them up when you stack them.
Old 08-01-2007, 08:29 AM   #19
s2man's Avatar
hmmm, leaving them separate could let one of them shoot out from under your tire if you accidently hit the gas or brake too hard. It's bad when my whole metal ramp shoots out from under the tire on slick concrete.
Back to your question, brucepick. As long as I can remember, my dad always had a pair of ramps/stands made from ~14" pieces of 2x4 assembled log-cabin style - about the size of a milk crate. The top pair of 2x's was set perpendicular to the tires so the tires nestled between the 2x's and didn't roll. I don't recall his ramp configuration, but it was removable (say, that sounds handy).
Boy, we used those blocks to support all kinds of stuff besides cars, we stood on them, etc. I may need to reinvent a set of those
Roll on,
S2man
s2man is offline   Reply With Quote
Mad Driver GasSavers_KenS Introduce Yourself - New member Welcome 4 12-27-2005 08:49 AM
