Heat Insulation/Dynamat insulator - Fuelly Forums
Old 06-23-2008, 02:19 AM   #1
goofy1's Avatar
i was using the old noodle, trying to think of a way to get Blackhawk to warmup faster to get to it peak power,fe, etc..Some do they whole grill blocking, which is something i was thiniing about. but then i had a brain fart. More insulation, i founthis stuff Dynamat insulator, it's a sound/heat padding. Wouldn't this in theory word to get the car to warm up faster(and not having to worry about it over heating)? and on the plus side cut back on the noise the engine makes? As anyone used this? i need some input (as Johnny 5 would say)lol
"But Doc, we dont' have enough road to get it up to 88 miles per hour"
goofy1 is offline   Reply With Quote
Old 06-23-2008, 02:32 AM   #2
Marvin has a big wad of something like that underneath the hood from the factory.
Old 06-23-2008, 02:38 AM   #3
goofy1's Avatar
so will it work? cause i'm worried about the overheating part of it.
Old 06-23-2008, 07:09 AM   #4
you'll be fine. your full on temps may be higher of course, but it will warm up faster. currently, my car has about an inch of this stuff from the factory on it. probably not as robust, but its there. When its 115 outside, its 210. Runs fine, I've never seen it above 215, even idling in traffic. Put it on, and use your grill block as the temp adjuster. I wouldn't worry. Although the extra weight may be a consideration to think about.
almightybmw is offline   Reply With Quote
Old 06-23-2008, 08:51 AM   #5
goofy1's Avatar
well tercel engine are good fe motors, but they are extremely easy to over heat. my temp runs like 175 or 185 i forget. but my mech. warned me with the raditor got a crack in it, to never like touch red because the overheat so easily. thats why i'm not sure on this.
But wouldn't the fan kick on to help cool down the engine?
I don't have grill block yet. i wanted to try this first. or should it be the other way around?
No more diesels in California Matt Timion Diesels 25 10-02-2008 06:56 PM
Higher speed not as bad as I thought mrmad General Fuel Topics 16 09-22-2007 09:55 PM
Low power consumption cd player mji988 General Maintenance and Repair 10 06-27-2007 06:53 PM
Bought two new mowers and weed wacker psyshack General Discussion (Off-Topic) 5 05-21-2007 08:17 PM
Altima aerodynamics Compaq888 Aerodynamics 21 06-22-2006 08:57 AM
