header wrap - Fuelly Forums
Old 11-12-2007, 08:50 AM   #1
93dagsr's Avatar
header wrap
has anyone tried to header wrap their headers down?? i mean like a full exhaust wrap (from header to exhaust tip)?? my mechanic did it and he said that the fuel consuption improved noticeably. also he wrapped his intake to provide further insulation and saw an improvement there! i was wondering if someone could crunch some numbers and see if it would benefit greatly or just a slight change??
https://consumerguideauto.howstuffwor...onda-civic.htm
stupid ricer... useless wings are for pinguins!
93dagsr is offline   Reply With Quote
Old 11-12-2007, 12:37 PM   #2
DarbyWalters's Avatar
Header wrap will work BUT it will hold in moisture and cause things (not aluminum of course) to deteriorate. Coatings are better in the long run...you can coat the outside and inside of exhaust pieces. Problem is initial cost is a bit but it will last the life of the car for most.
If you want to learn more...google...Swain Technology...Swain Coatings...something like that...he is out of New York...good info on the site.
I don't know if it is going to make a huge difference when going for FE...It has more potential for improvement at WOT (Wide Open Throttle)....horsepower wise anyway.
Old 11-12-2007, 01:03 PM   #3
93dagsr's Avatar
yea i was thinking about that too. i guess i don't really have that problem since i live in the desert and get little to no moisture. my friend really hasn't had any problems at all.
Old 11-12-2007, 02:47 PM   #4
cfg83's Avatar
93dagsr -
Here's a thread on the subject :
exhaust wrap - interesting results
http://www.gassavers.org/showthread.php?t=1753
However, as you can see, lindermant removed the wrap because he was afraid his cat would melt/be destroyed.
Old 11-13-2007, 07:26 AM   #5
93dagsr's Avatar
i see. so wraping is not at all the best option
Old 11-13-2007, 06:17 PM   #6
ZugyNA's Avatar
I'd like to hear what he did that on and how...andwhat kind of mileage gain he got. Makes sense if done in summer...cooler air in...not sure how hotter exhaust would help except for the O2.
Old 11-16-2007, 03:45 PM   #7
I don't see how that would help horsepower either. Hotter air is less dense and requires more pipe area or a higher speed to get it out of the back as opposed to air that is allowed to cool. Torque might go up seeing as EGV would be higher. You wouldn't need to step the pipes down closer to the back to maintain a high exhaust gas velocity.
- Kyle
Old 11-16-2007, 08:46 PM   #8
unstable bob's Avatar
Send a message via AIM to unstable bob
The exhaust wrap will also absorb any stray oil and other contaminants, making for a potential fire hazard. I saw a mint Z28 Camaro go up in flames once because the wrap on the headers became oil soaked and caught fire.
unstable bob gable
AMERICAN ROAD WARRIOR!
www.unstablebobgable.com
1973 AMC AMX: The beauty
1987 Buick T-Type: The beast
unstable bob is offline   Reply With Quote
Old 03-11-2008, 06:43 AM   #9
Ceramic Coating
Well , This is my first post . Just picked up a 92 VX and am stoked . 45 mpg on my first take with the PO driving 150 miles . I just happen to own a coating shop and I will be coating my system here shortly and posting results for FE . As far as performance we generally see a .5-1% increase in hp and torque . This is acomplished by increasing exhaust velocity and decreasing intake air temp from heat transferred from exhaust . This also increases life of the exhaust system as well as other under hood parts due to a decrease in heat transfer . On average you will see a 40% decrease in surface temp on headers . I will post updates here as well as on our current projects page @ www.performancekote.com
performancekote is offline   Reply With Quote
Old 03-11-2008, 07:00 AM   #10
GasSavers_SD26's Avatar
+1
Increased exhaust velocity is a great benefit. I've used Swain in the past for stuff.
Welcome to the board performancekote!
Dave
Can't delete fill ups posted by a friend. missmaispace Fuelly Web Support and Community News 4 08-18-2014 10:18 PM
wont let me enter a fuel up :( Joloke Fuelly Web Support and Community News 4 10-29-2009 07:19 AM
Cam regrinds for Atkinson cycle? omgwtfbyobbq General Fuel Topics 14 07-11-2007 07:03 AM
Honda 2005 1.8L i-VTEC 88HF General Fuel Topics 4 07-09-2007 06:40 PM
Noob trying to save in gas! GasSavers_Bigfoot Introduce Yourself - New member Welcome 1 05-31-2007 01:17 PM
