header wrap - Page 2 - Fuelly Forums
Old 03-11-2008, 07:32 AM   #11
Site Team
Originally Posted by dkjones96 View Post
I don't see how that would help horsepower either. Hotter air is less dense and requires more pipe area...
Lower viscosity of the exhaust gas
Old 03-11-2008, 01:52 PM   #12
holypaulie's Avatar
exhaust wrap lower my temp
After upper grill block and bellypan my underhood temp went up and the best solution for me was to wrapped exhaust manifold. Works great for me without any problems
Old 03-12-2008, 09:30 AM   #13
IMO header wrap will be most effective on normally aspirated engines when the exhaust system is perfectly sized or a touch undersized. Most folks can't help themselves when getting a performance exhaust or header though and have it too large, velocity is already sub-optimal, and wrapping the header will have marginal gains. On a correctly sized exhaust, which may include many stock exhausts, I think it will be more noticeable. However stock exhaust systems can be under or oversized too. Wrapping might help an undersized one on the low end quite a bit, but it will do practically nothing for an oversized one until it's bouncing off the rev limiter.
When the exhaust system is tuned perfectly, the momentum of the exhaust gases provides a small amount of suction just before exhaust valve closing, that helps extraction, may provide a small amount of positive effort to the piston (depends on timing) and with valve overlap, can kick start the movement of the intake charge, which is sitting static just as the intake valve opens. Result less parasitic loss.
So, what you're hoping for with wrapping is to keep velocity high in the header and downpipe, not allowing flow stalls due to cooling.
The way I'm thinking right now, I believe that short of a custom header, the piping sizes are about right on Marvin, but his exhaust ports need a little restriction... on Wile-E... the exhaust ports and cast header are cavernous, twice the size they need to be, but the rest of the system is a touch undersized, it could do with being 2" all the way back, but it's only 1 7/8 or 1 3/4. Might need 2 1/4. I will have to see how much effect high compression modifications and porting makes. I'd like to get Wile-E a stock '90 or earlier escort GT header, needs some modification though. Anyway, plan to wrap things up for Marvin when the "new" motor goes in, and assess Wile-E's needs when I see how the mods run.
Being a cheapskate, I'm probably just gonna buy generic woven glass tape, not the same stuff priced up as header wrap.
Old 02-05-2009, 04:34 PM   #14
Update
Just a quick update. After coating the entire exhaust ( stock setup ) I have gained an average of 2 mpg. www.performancekote.com More to come
performancekote is offline   Reply With Quote
Old 02-05-2009, 05:01 PM   #15
GasSavers_SD26's Avatar
Please post your gas log info...
Dave
Old 02-06-2009, 09:35 PM   #16
suspendedhatch's Avatar
If you can imagine cold air on the intake side improving power, then you should be able to imagine the same thing for hot air on the exhaust side. In theory, you want the exhaust to stay hot all the way out. The same way you want a turbo to get hot. But in practice it's highly unlikely that it's enough to make any noticeable difference to either power or fuel economy.
I had a large section of my exhaust wrapped on my previous Civic in order to try to reduce the noise. Didn't work for that either.
Can't delete fill ups posted by a friend. missmaispace Fuelly Web Support and Community News 4 08-18-2014 10:18 PM
wont let me enter a fuel up :( Joloke Fuelly Web Support and Community News 4 10-29-2009 07:19 AM
Cam regrinds for Atkinson cycle? omgwtfbyobbq General Fuel Topics 14 07-11-2007 07:03 AM
Honda 2005 1.8L i-VTEC 88HF General Fuel Topics 4 07-09-2007 06:40 PM
Noob trying to save in gas! GasSavers_Bigfoot Introduce Yourself - New member Welcome 1 05-31-2007 01:17 PM
