Has anyone tried hho on 2 stroke - Fuelly Forums
Old 05-04-2008, 08:32 AM   #1
Has
acetone marty is offline   Reply With Quote
Old 05-04-2008, 10:39 AM   #2
flapdoodle's Avatar
I tried injecting HHO directly into the intake of my Weedeater outboard conversion at various throttle settings.
There was no difference in RPM that I could detect. However, these little engines have peculiarities that may not be encountered by others. Oil is added to the gasoline, the carburetor is designed to run at any angle, and I have doubts that they have fuel efficiency in mind in the design.
Adjusting the ignition timing is a major project.
Old 05-04-2008, 08:39 PM   #3
GasSavers_Ryland's Avatar
I have not seen proof that it works on a 4 stroke, so I don't see why it would work on a 2 stroke, all of the gains I've seen would be best attributed to placebo affect on the driver.
If you really want to try it and be sure about it, get a tank of hydrogen from a welding shop.
Old 05-05-2008, 05:09 AM   #4
ZugyNA's Avatar
mrgalleria on this forum claims good gains for a moped:
http://oupower.com/phpBB2/viewforum....14c0af41959084
Identifying a CX/VX Transmission GasSavers_scostanz General Maintenance and Repair 40 10-24-2011 04:51 PM
A shot with a mix... GasSavers_SD26 Diesels 23 03-13-2008 06:20 PM
Air scoop for mpg? ZugyNA Experiments, Modifications and DIY 10 12-05-2007 10:40 AM
Brake Puck Return Tool - Home Made Mayhim Experiments, Modifications and DIY 0 11-27-2007 12:33 PM
BIG car Andy-Paul Transmissions and Running Gear 30 10-24-2007 02:25 PM
