Hair Dryer Power! - Page 5 - Fuelly Forums
Old 08-07-2007, 04:41 AM   #41
I think I would only run it for 5 or 10 minutes at a time, at cold starts. When my wife dries her hair it definitely runs for longer than that... To power the 1000 watts of heat you would need a mighty stout inverter...
Old 08-11-2007, 07:41 PM   #42
kwtorbe's Avatar
Or use a gas powered leaf blower sucking air off the exhaust manifold : )
kwtorbe is offline   Reply With Quote
Old 09-13-2007, 07:20 PM   #43
dont intake manifolds have coolant runnign trough them for this purpose? i know my 1993 240sx does
joeldude is offline   Reply With Quote
Old 07-27-2008, 03:48 PM   #44
I have been thinking the exact same thing you have, (a hairdryer!!!) except I was going to turn the temp. on the hair dryer to "warm" for a warm air intake. Also, i was thinking of removing the fan from it and leaving the heating coil inside so it would just be considered a heater.
hound_13 is offline   Reply With Quote
Old 07-27-2008, 05:05 PM   #45
On EFI equipped car there is an intake temp sensor, this sensor helps determine how much fuel to inject and how much timing the air can handle. Higher temperatures mean the air can handle less fuel before it goes rich, conversely the cooler the air the more fuel it can support. Since we here are not so concerned about peak power and high MPH, high intake temps are a good thing. My car for instance has manifold pressure based fuel mapping but the IAT (intake air temp sensor) determines the offset on a given map. I run a hot air intake (as seen in my garage) my intake temps run between 130* and 140* f compaired to the 78*f without, my fuel usage went from 1.5 gallons per hour (GPH) to just 1.09GPH at the same throttle setting (cruise 65 mph) this netted a huge gain in cruise milage. Again we aren't looking for low quarter mile times just good MPG's.
Old 07-27-2008, 06:27 PM   #46
GasSavers_BEEF's Avatar
phil hit the nail on the head. less power but more FE. the trade off is there and has always been there. I have heard that it doesn't work so well on all vehicles but I personally saw about 10% gain out of mine too. taking the heat off of the header (exhaust manifold).
Old 07-27-2008, 06:31 PM   #47
Originally Posted by diamondlarry View Post
Cool air is good for making more power but warm air is better for mileage because it helps vaporize the fuel better. Unvaporized(liquid) fuel doesn't burn. Cool air would not allow as much vaporization.
Less O2 = less gas.
So hot air effectively makes the motor smaller...
Looks like the price you entered for a litre of gas is unrealistic. winstona Fuelly Web Support and Community News 6 05-12-2013 10:26 AM
Over 100 Gallons twbhd04 Fuelly Web Support and Community News 14 06-20-2011 08:09 AM
A side project I am working on... DTMAce General Fuel Topics 3 04-29-2010 02:21 PM
Diesels are very efficent at idle? philmcneal Diesels 36 04-05-2007 06:25 PM
Recommendations for a tire gauge Compaq888 General Fuel Topics 10 04-21-2006 02:18 AM
