Hair Dryer Power! - Page 3 - Fuelly Forums
Old 12-09-2005, 06:33 PM   #21
FE nut
diamondlarry's Avatar
You could go to
You could go to www.scaguage.com for a product that is pretty good for monitoring mpg. Also, if you want a product that is really good for monitoring engine parameters such as O2 sensor outputs, long and short term trim levels and such, this is a pretty good product: http://www.auterraweb.com/ Welcome to the group!
2007 Prius,
Team Slow Burn
Old 12-09-2005, 10:21 PM   #22
Matt Timion's Avatar
Re: You could go to
If your car is made after 1996 Scangauge is your best bet. It will monitor air temp, engine temp, mpg, etc. I'm not certain about data logging though, but I'm pretty sure with obd2 (post 1996) you can easily get toys for things like this.
For those of us with older cars, we're still trying to figure out the best way to monitor gas mileage. We'll figure something out sooner or later.
Old 12-10-2005, 06:23 AM   #23
I have a 1951 truck with a
I have a 1951 truck with a 96 Ford engine but I did not use the computer. Thanks for the links. I'll look at them.
GasSavers_dean is offline   Reply With Quote
Old 03-24-2006, 11:15 PM   #24
GasSavers_Ryland's Avatar
yes, fuel will vaporize
yes, fuel will vaporize better in warm air, but your engine will run more efficently if it has cold, dense air because it gives a simaler affect as a turbo, and if done right, a turbo engine can get the same mileage, or better, while producing more power, becasue of the extra air it's packing in there.
and a hair dryer doesn't produce enough presure to make any differnce, it might put out .5 psi, while a turbo is 15-20 psi, or more.
Old 03-25-2006, 06:45 AM   #25
I'm glad you're going around
I'm glad you're going around ressurecting some old threads, , some of these things have nuggets in them.
Old 03-25-2006, 07:09 AM   #26
Warm air intake
Yanno, it just occurred to me that the easiest warm air intake system would be a tube with an orfice that pushes a metered amount of EXHAUST GAS into the intake manifiold. EGR has been used for years to reduce NOx emissions, so why not apply it to fuel economy?
The tubing would be tiny compared to hair dryers, catalyst shrouds, and ducting from the catalyst, etc. And the whole thing would be reversible at inspection time.
Has anybody tried this?
Old 03-25-2006, 07:12 AM   #27
Re: I'm glad you're going around
At first I was like who brought up the hair dryer thing again! But there's more to it. You're right, despite the title, there might be some valuable off-topic gems to mine.
Old 03-25-2006, 07:12 AM   #28
Well, from my standpoint,
Well, from my standpoint, the egr system that honda designed has not just emissions purposes, but gas mileage purposes as well. I will be doing this buy installing a stock intake manifold and egr system in the future.
How do you plan to scoop up the exhaust gasses though?
Old 03-25-2006, 09:32 AM   #29
Also from my standpoint GM
Also from my standpoint GM designed my egr system on my engine to also affect FE in a positive way (the 60°V6 guru/ecu programmer I know mentioned this when I told him i was interested in piggy-back chipping my motor)
-unknown
Old 03-26-2006, 08:37 AM   #30
EGR tweeking
at what point does the EGR valve open? and would leaning out the o2 in your "air" really have that much of an affect? I meen, I'm sure you could lower the amount of fuel going in if you lowered the o2, but wouldn't you almost need to cool the exaust gasses befor the go in the combustion chamber, so they can exspand again with the rest of the gasses?
and would you have a problem with the o2 being to scattered to be able to burn all the fuel?
Looks like the price you entered for a litre of gas is unrealistic. winstona Fuelly Web Support and Community News 6 05-12-2013 10:26 AM
Over 100 Gallons twbhd04 Fuelly Web Support and Community News 14 06-20-2011 08:09 AM
A side project I am working on... DTMAce General Fuel Topics 3 04-29-2010 02:21 PM
Diesels are very efficent at idle? philmcneal Diesels 36 04-05-2007 06:25 PM
Recommendations for a tire gauge Compaq888 General Fuel Topics 10 04-21-2006 02:18 AM
