HAI Experiment - Fuelly Forums
Old 12-04-2009, 04:16 AM   #1
Originally Posted by spotaneagle View Post
[PDF]
BURNER DESIGN PARAMETER FOR FLUE GAS NOx CONTROL
Tests on gas turbines
developed for the automobile in the early 1960's
indicated that NOx emissions were lower on warm,
humid days as opposed to cold, dry days. Also, in the
case of gas turbines, water is injected to limit the
formation of the NOx in the combustion process.
johnzink.com/products/burners/pdfs/tp_burn_dez_params.pdf
also maybe you think nox would be too high on a warm intake system cause nova
misquoted this article where the cause of high NOx was a bad 02 sensor causing this car to run lean..
http://www.asashop.org/autoinc/oct2004/techtips.htm
NOx is generally the result of really high temperature exhaust(my edit: caused by clogged cat, not letting exhaust gas escape, not a warm air intake). Being the son of a mechanic, it is difficult for me to say what is beyond the scope of most individuals. I would richen the mixture slightly to lower temperatures, or advance the timing slightly. I think that will cool the engine down enough. A 30 minute run on the highway straight onto the test dyno would likely help if you can arrange it.
http://ask.metafilter.com/39612/How-...-NOx-emissions
wouldnt a warm air intake reduce exhaust temps somewhat by pulling air over the exhaust???
The technician installed a new O2 sensor and started the vehicle. Within a minute or two we had proper closed loop operation, and when he test drove the vehicle, he had vacuum to the EGR valve and the NOx failure was repaired.
running lean will cause high nox
if youre worried about nox, then DONT drive a deisel
Originally Posted by R.I.D.E. View Post
Better mileage=lower emissions.
Not always. If too lean you get higher NOx emissions.
Warmer air=better atomization
That was true for carbureted cars that didn't atomize fuel well. That's not the case with fuel injected car where fuel atomization is much better.
also:
70 C is close to 160 F. They found that past that knock could become a problem and BSFC would go back up a bit.
and i believe this works better in MAP systems and not MAF systems
As the son of a B17 pilot, that does not make me a qualified B17 pilot spotaneagle.
You still seem to have this propensity to inject words into my statements to try to slant the meaning.
Warm air reduces NOX
Better mileage reduces NOX.
Never said anything about running lean, so you need to stay within the contents of my quote or your priorities become obvious (trying to refute my statements for whatever reason).
In fact if HCCI is ever developed to the point of practicality, then your assumption about lean mixtures causing NOX would also be WRONG.
LEAN MIXTURES AND POOR ATOMIZATION CREATE NOX. HCCI addresses incomplete combustion under lean conditions by thoroughly emulsifying the mixture, while virtually eliminating NOX.
That's a lean mixture without excess NOX. In fact virtually no NOX.
Get it right son.
Now lets look at warm air induction. Take it to the reverse extreme, very cold air. As incoming air temperatures drop, fuel atomization is affected. Think 40 below 0, or even lower. At some point in lower temperatures the fine droplets of fuel injected into the engine will not completely vaporize and incomplete combustion will occur. Since incomplete combustion occurs at any temperature (demonstrated by the gains in efficiency of HCCI and the significant funding and research in developing practical HCCI systems) YOUR assumption that lean mixtures directly affect NOX is also flawed.
Lean mixtures and imperfect homogenization of the mixture create NOX. HCCI clearly proves that lean mixtures alone do not cause NOX spikes. Lean mixtures combined with imperfect homogenization do cause NOX increases.
Do the necessary research, and then refute my statements, or try just presenting the facts and let the readers draw their own conclusions.
regards
Gary
Incorrect mileage calculation? tonedepear Fuelly Web Support and Community News 6 04-04-2011 12:04 AM
No EPA Est for 2007 Chrysler Town & Country jklaiber Fuelly Web Support and Community News 1 08-23-2008 12:15 AM
ecu wiring green swift General Fuel Topics 0 05-09-2008 04:04 PM
Memorial Day. Remember those who died for our country. CO ZX2 General Discussion (Off-Topic) 5 05-28-2007 06:42 AM
WTB: HX or VX Wheels GasSavers_DaX Wanted to Buy 6 07-12-2006 09:50 PM
