HAI Experiment - Page 17 - Fuelly Forums
Old 04-08-2009, 10:40 AM   #161
MAX NOX is a direct function of peak combustion temperatures. Exhaust Gas Recirculation was the first solution back in the late 60s.
By adding exhaust gas to the intake mix the peak temperatures were lowered abbout 300 degrees. When people tried to disconnect them the engines knocked themselves to death unless they retarded the timing which caused power losses and unburned hydrocarbons.
Modern engines have, some cases eliminated EGR by changing valve timing of the exhaust valves to keep more exhaust gas in the combustion chamber without the necessity for an egr valve.
I always hated EGR beacuse when it combines with PCV vapors it forms a tar like residue in the intake manifold, and when the EGR passageways become plugged, the CPU retards the ignition to prevent knocking and your power and mileage suffer significantly, because the system was designed to work properly with EGR.
regards
gary
Old 04-08-2009, 10:43 AM   #162
Originally Posted by R.I.D.E. View Post
To assume that warmer air causes higher NOX emissions just doesn't hold water as a logical argument.
Sorry but that is true. The higher the combustion chamber temps, the higher the NOx emissions.
http://www.asashop.org/autoinc/oct2004/techtips.htm
GasSavers_NovaResource is offline   Reply With Quote
Old 04-08-2009, 10:45 AM   #163
Warmer air does not produce higher combustion chamber temperatures.
regards
gary
Old 04-08-2009, 10:47 AM   #164
Yes, it does
Old 04-08-2009, 10:49 AM   #165
Same fuel being burned in a higher volume of gas should lower peak temps shouldn't it?
co de pen den cy
Function: noun
Date: 1979
Old 04-08-2009, 10:52 AM   #166
A rich mixure runs cooler than a lean one.
Old 04-08-2009, 11:14 AM   #167
This debate is suffering badly from lack of data, and lack of new arguments. Everyone seems to be going back and forth with the same stuff. So, I googled it up, and found lots of information on another hypermiling forum. I'll post it in chunks to make it easier to review and respond.
MetroMPG, the guy whose test is being used as an anchor of the anti-WAI argument, insists that his test is only valid for his vehicle:
http://ecomodder.com/forum/showthrea...rence-529.html
...also, he continues to run the WAI in spite of that test, because of the warm-up gains:
http://ecomodder.com/forum/4225-post11.html
That's because of his own tests not regarding steady-state driving:
http://ecomodder.com/forum/showthrea...iment-432.html
His own testing shows that it does increase FE even on his car, just not during steady-state driving.
Old 04-08-2009, 11:21 AM   #168
Research done by Honda (didn't someone mention them earlier as a company that would use WAI?) on IAT's effect on BSFC and power:
http://ecomodder.com/forum/94385-post19.html
This is from a 1989 research paper by Honda on their F1 1.5L turbo engine. The following images are at WOT:
Old 04-08-2009, 11:21 AM   #169
Successful gaslogs:
http://ecomodder.com/forum/em-fuel-l...?vehicleid=104
http://ecomodder.com/forum/em-fuel-l...?vehicleid=176
http://ecomodder.com/forum/16689-post32.html
My '00 Civic (with knock sensor) is showing ~10% mileage improvement with a WAI pulling hot air from right next to the exhaust manifold. Aside from driving style, it has been the best single thing I've done for FE.
Testing that was done that shows WAI helps:
http://ecomodder.com/forum/showthrea...-fwt-1506.html
Ford Man, a member here, posted this on ecomodder:
http://ecomodder.com/forum/90155-post1.html
I recently got the idea to block the door from the exhaust manifold to the breather in the open position all the time to act as a WAI. Since doing this I've been seeing considerablely better mileage. MPG since doing this have been 46.478, 41.976, 44.198, 44.2 and 42.853. Some of these mileages are in line with what I usually get during summer months when the weather is warm and have summer blend gas.
Other users in that thread reporting improvements:
http://ecomodder.com/forum/96398-post8.html
http://ecomodder.com/forum/95349-post5.html
Old 04-08-2009, 11:22 AM   #170
References to data published in books:
http://ecomodder.com/forum/17092-post39.html
http://ecomodder.com/forum/22749-post15.html
http://www3.fs.cvut.cz/web/fileadmin...006_077_01.pdf
"In this research, they were able to reduce BSFC at low RPM and low load by 7% at 195 F vs 100 F."
From the PDF:
ABSTRACT
Within the framework of research and development (R&D) activities on four-cylinder internal combustion (IC) engine in a low load state, a research for influence of mixture temperature on engine parameters has been performed. Content of this article will be describe of changes of low load engine parameters by increasing of mixture temperature. On the base of measured data, the increasing of mixture temperature causes increasing of mixture combustion rate and it has a positive effect on the low load engine parameters, especially on fuel consumption. Achieved results in this topic give impulse for continue of this research.
Incorrect mileage calculation? tonedepear Fuelly Web Support and Community News 6 04-04-2011 12:04 AM
No EPA Est for 2007 Chrysler Town & Country jklaiber Fuelly Web Support and Community News 1 08-23-2008 12:15 AM
ecu wiring green swift General Fuel Topics 0 05-09-2008 04:04 PM
Memorial Day. Remember those who died for our country. CO ZX2 General Discussion (Off-Topic) 5 05-28-2007 06:42 AM
WTB: HX or VX Wheels GasSavers_DaX Wanted to Buy 6 07-12-2006 09:50 PM
