HAI Experiment - Fuelly Forums
Old 03-24-2009, 06:19 AM   #1
GasSavers_BEEF's Avatar
his test is total BS?
I don't see you doing any testing. it is easy to discredit someone elses efforts. where are yours? he is at least doing something.
the whole "not good enough" thing is easy to say when you have done nothing. if you don't agree with his results, do one yourself. disprove him the scientific way, not just by saying it's BS.
it is nice to see our newer members contributing so much
Old 03-24-2009, 06:58 AM   #2
More good reading:
http://www.nextautos.com/auto-shows/...inject-engine/
Mazda has announced its new lineup of direct-injection engines, called the DISI (direct injection spark ignition). The announcement of the performance enhancing, fuel conscious engines comes only weeks after Ford?s EcoBoost announcement.
The I-4 DISI engine seeks to achieve a 15-20 percent improvement in performance and a 20 percent increase in fuel economy over Mazda?s 2.0L engines.
According to the press release, the DISI engine will reduce energy loss and improve thermal efficiency with a variety of technological engineering. This includes cooling the air intake temperature and reshaping the combustion chamber.
Mazda also noted that they are looking to produce direct-injection diesel turbo engine technology that can improve the fuel economy and emissions by 10 percent as well.
http://www.passagemaker-digital.com/.../200903/?pg=81
Related to air filter performance is the temparature of the air being consumed by the engine. Warm air is thinner or less dense than cool air, and thinner air burns less efficiently. Therefore, it is desirable to keep the air inlet temperature to a minimum.
GasSavers_NovaResource is offline   Reply With Quote
Old 03-24-2009, 07:07 AM   #3
OK what are you doing to improve your milage? OH RIGHT NOTHIING you are barely beating EPA ratings. You obviously have no intention of trying anything and you want us to join you. The truth of the matter is IF automakers gave two damns about milage I would be getting 50mpg out of the car with no mods. so get off your high horse and do something rather than just nay saying everyone here or go away in general. I am tired of arguing with a person who has no intention to try anything so I will not continue arguing with a troll.
Old 03-24-2009, 07:27 AM   #4
Post deleted due to inappropriate content
Old 03-24-2009, 07:44 AM   #5
Originally Posted by NovaResource View Post
And the insults start. When all else fails, throw insults.
You've thrown posted a few pretty insulting things when discussing this topic too (giant cookie?). Let's all try to avoid them in general, OK?
co de pen den cy
Function: noun
Date: 1979
Old 03-24-2009, 07:50 AM   #6
Post removed due to attacking other members
Old 03-24-2009, 07:52 AM   #7
The cookie was humor. It was not a personal attack.
I took it as extreme sarcasm. I apologize for misreading it. No tone or inflection.
co de pen den cy
Function: noun
Date: 1979
Old 03-27-2009, 06:02 PM   #8
Here goes. Last week my milage was 192.1 miles and I used 8.339 gallons for an MPG of 23.03. That will be baseline #1 for using the stock cold air inlet.
Today I filled up again:
256.4 miles
11.207 gallons used:
For an MPG of 22.87. That will be baseline #2 for the stock cold air inlet. Both numbers are similar and fairly typical for me in the winter.
Removing the factory cold air inlet. Here's the stock setup:
Closeup of the inlet on the outside of the radiator support:
Here the hose connecting the inlet to the air box is disconnected from the inlet and pointed towards the radiator and exhaust manifold to pick up warm, engine air:
Here the inlet is blocked off with duct tape to prevent any cool air from entering.
The inlet was secured in place with a wiretie to prevent it from moving. One week from today I'll have my first data from a WAI. My schedule for next week is almost identical to this past week so mileage should be close to the same.
Old 04-04-2009, 04:14 PM   #9
256.4 miles
8 days later of a WAI and here are the results.
Today I filled up again.
263.0 miles (difference of 6.6 miles or 2.5% from last test):
11.566 gallons used (exact same station and pump uesd):
For an MPG of 22.73. That's a loss of 0.14 mpg with the WAI.
Conclusion: FAILURE
There is statistically ZERO benefit from a WAI. It doesn't appear to hurt mileage but it does not help. And with the obvious loss of power this is not a modification anyone should do unless the engine and computer are designed for lean burn.
I'm hooking the cold air duct back up and seeing the difference next week.
Old 04-08-2009, 05:22 AM   #10
101mpg's Avatar
You haven't done significant A-B-A testing. A-B, and one more tank is A-B-A, but butt dyno, your wanting it to fail, etc., have likely contributed. Do SIGNIFICANT testing - like A-B-A, 5 tankfuls on each. WAI may not work on YOUR vehicle, either. It does work for some, but not for all. That has been established.
You'll note my vehicle is in the top 10 for % over EPA, btw - and it's an automatic, so I can make claims about getting significant mileage increases from a position of security.
Conclusion: FAILURE
Incorrect mileage calculation? tonedepear Fuelly Web Support and Community News 6 04-04-2011 12:04 AM
No EPA Est for 2007 Chrysler Town & Country jklaiber Fuelly Web Support and Community News 1 08-23-2008 12:15 AM
ecu wiring green swift General Fuel Topics 0 05-09-2008 04:04 PM
Memorial Day. Remember those who died for our country. CO ZX2 General Discussion (Off-Topic) 5 05-28-2007 06:42 AM
WTB: HX or VX Wheels GasSavers_DaX Wanted to Buy 6 07-12-2006 09:50 PM
