HAI Experiment - Page 19 - Fuelly Forums
Old 04-08-2009, 04:19 PM   #181
Otto cycle is spark ignition.
Diesel is compression ignition.
HCCI is basically combination of the 2. It’s compression ignition using gasoline instead of diesel. There is no spark to ignite the mixture. Instead, like a diesel, the density and temperature of the mixture are increased by compression until the mixture ignites spontaneously.
GasSavers_NovaResource is offline   Reply With Quote
Old 04-08-2009, 04:22 PM   #182
Maybe you should Wicki "Otto Cycle". Diesel and gas are both Otto cycle.
regards
gary
Old 04-08-2009, 04:29 PM   #183
Similar, but not the same. Diesel is compression ignition, otto cycle is spark ignition.
Old 04-08-2009, 04:40 PM   #184
You are backpedaling now. Otto cycle is not determined by the ignition source.
regards
gary
Old 04-08-2009, 04:43 PM   #185
I'm not backpedaling at all. The two are not the same. Similar because the diesel is based off the otto cycle.
Old 04-08-2009, 04:51 PM   #186
So which is correct? This statement or your latest.
As I stated check Wicki, Otto cycle includes both diesel and spark ignition. HCCI engines use spark ignition initially until the heat energy necessary to obtain HCCI becomes available.
The operational cycle remains Otto regardless of the ignition source.
Provide proof of your definition with references, as I have.
regards
gary
Old 04-08-2009, 04:53 PM   #187
Both statements are correct. Otto cycle is spark ignition. Diesel-cycle is based off the otto-cycle but uses compression ignition.
I see no references in your posts but here's mine:
http://books.google.com/books?id=hA1...sult&resnum=10
Old 04-08-2009, 05:02 PM   #188
I think the conclusion is obvious to all the other readers of this thread.
regards
gary
Old 04-08-2009, 06:10 PM   #189
What's that? That you are trying to prove me wrong and discredit me?
Old 04-08-2009, 07:30 PM   #190
I thought that the consensus was that HAI/WAI works for some vehicles, and doesn't for others depending on engine and fuel system design. I don't think there's anyone here saying that it will work on any vehicle.
Incorrect mileage calculation? tonedepear Fuelly Web Support and Community News 6 04-04-2011 12:04 AM
No EPA Est for 2007 Chrysler Town & Country jklaiber Fuelly Web Support and Community News 1 08-23-2008 12:15 AM
ecu wiring green swift General Fuel Topics 0 05-09-2008 04:04 PM
Memorial Day. Remember those who died for our country. CO ZX2 General Discussion (Off-Topic) 5 05-28-2007 06:42 AM
WTB: HX or VX Wheels GasSavers_DaX Wanted to Buy 6 07-12-2006 09:50 PM
