Grill block questions - Page 3 - Fuelly Forums
Old 11-08-2007, 06:32 PM   #21
Originally Posted by Antares2k6 View Post
I did not put one or two of them in km's. Live in Canada, should have done that.
Antares
that was my thought. that said, i believe you may go w/ FULL grill blocks, top and bottom, at least thru winter in your kinda cold. i'll be watching your logs w/ interest. best FE to you.
Old 11-08-2007, 07:02 PM   #22
dang i gotta update mine... i havent done for like 2-3 fillups... ill do it sometime later cuz i gotta fill up in my truck soon
Old 12-30-2007, 12:15 PM   #23
grill block
Different cars are effected in different ways. Many camaro grills for example are below the bumper. The radiator air enters below the bumper flows upward throuh the radiator and into the engine compartment. If placing an air dam on the later generation camaros, place the dam directly underneath the radiator, not under the front. I work for a Chevy dealer and we have had mystery overheating problems on lowered camaros due to a misplaced or misinstalled air dam. I have seen the same effect on other vehicles with an air dam lower in front than the one below the radiator. It all depends on where the front end flow is designed to go, over or under the front bumper.
Keep working on the experiments. In '85 before Nascar started installing governors, Tim Richmond hit 240 MPH at Michigan during testing by completely blocking off the front end, (he could only run 2 laps before overheating)
trailrunr is offline   Reply With Quote
Old 12-30-2007, 02:22 PM   #24
kamesama980's Avatar
for the winter, I put 2 pieces of AL scrap I had laying around in my grill blocking about 80-90% and my temp gauge starts creeping when it's 45 outside in just highway cruising @ 60 mph. yes my cooling system is fully functional and clean I even removed the AC condenser in front of the radiator, the car just runs that warm.
-Russell
Old 01-09-2008, 08:32 PM   #25
Send a message via AIM to eivad1 Send a message via Yahoo to eivad1
yeah but how does going from a 180 to 195 make it more efficient for the gas mileage
eivad1 is offline   Reply With Quote
Old 01-10-2008, 03:16 AM   #26
a warmer engine, w/out over heating, runs more efficiently.
Old 01-10-2008, 02:59 PM   #27
s2man's Avatar
I saw no temperature changes with either my temp or permanent grill blocks on my Cavalier. This is due, no doubt, to the huge opening between my bumper and radiator. Closing that hole is the next aero mod on my list.
Speaking of warmer engine temps, I finally got fed up with low temps this winter, and took action this morning; I covered about 2/3 of the radiator with cardboard, leaving it open in front of the fan. I had been running 130-140*F on the highway, but I ran at thermostat temps of 180* both ways today. Yea! And I'm running at cooling fan temps of about 204* when I get off the highway. Now I really want to get my 195* 'stat installed...
Roll on,
S2man
s2man is offline   Reply With Quote
View model averages? unicrombie Fuelly Web Support and Community News 4 11-09-2011 07:32 AM
super mid Hockey4mnhs General Fuel Topics 5 06-03-2007 01:57 PM
HF to SI tranny swap complete, questions about tire size... white90crxhf General Fuel Topics 1 08-20-2006 07:46 PM
Gas Log? GasSavers_Kraig General Discussion (Off-Topic) 3 08-16-2006 02:21 AM
Toyota Grand Prius krousdb Automotive News, Articles and Products 5 07-26-2006 03:44 PM
