Graphite dust in transmission oil? - Page 2 - Fuelly Forums
Old 07-07-2010, 07:31 AM   #11
add|ct's Avatar
Originally Posted by fowljesse View Post
Heheh. I heard of using brownies in the rear diff. No lie.
I would like to decrease the friction in my manual transmission. I don't have any problems, and am going to rebuild it soon, so I'm thinking about possible experiments in the mean time.
If you're going to re-build it soon, go with an AutoRX product prior to doing so instead!
'92 Civic VX, Canadian model
Old 07-07-2010, 09:16 AM   #12
GasSavers_Erik's Avatar
I am curious- why are you going to rebuild the trans if there are no problems with it?
Old 07-08-2010, 06:45 AM   #13
Member
What kind of sawdust is best, hardwood or softwood? And what is the ideal proportion to mix it?
markweatherill is offline   Reply With Quote
Old 07-08-2010, 07:09 AM   #14
Plus, what size? Chainsaw chips, drill chips, rough circular saw dust, fine dust...
Old 07-08-2010, 08:45 PM   #15
GasSavers_JoeBob's Avatar
Pine, left over from sawing 2x4s from house framing, is probably best. Mix in some...you'll "know" when you've mixed in enough.
BTW...way back in the before time, I used to use Arco Graphite motor oil. Always worked fine for me, even in my Triumph 650 with a wet clutch. Only problem was that it was really messy when oil would spray onto my good clothes...
Old 07-21-2010, 11:28 PM   #16
fowljesse's Avatar
Huh. Well, that's what I'm talking about. There must be a reason they don't use it anymore.
The reason I'm rebuilding it is to put in taller gears, and final drive, and an LSD. While it's out I have an aluminum flywheel, and stronger clutch to put in.
fowljesse is offline   Reply With Quote
Old 07-24-2010, 04:55 PM   #17
I'd imagine if graphite was a beneficial additive it'd already be in one of the higher quality, higher priced, or race-bred and race-targeted brands.
the lack thereof should answer the question. There are some with Molybdenum Disulfide in there, but not much. It's a "little goes a long way" situation.
odiekokee is offline   Reply With Quote
Are these wheels worth it? Improbcat General Fuel Topics 17 05-24-2008 05:01 AM
New HHO Setup nsgrossman Experiments, Modifications and DIY 4 02-08-2008 01:57 AM
