Well about 3 hours of moving it closer to the welder and jacking it up with 3 jacks and a turnbuckle to pull it into alignment, a small bracket of steel has been welded into place to support the front edge of the swingarm. Almost all of the bottom of the wheel well tower that the a-arm pin bolts to was rusted away. Took a bunch of photos before, during and after. The left side looks ok but we will sealing it up with cosmoline to prevent further damage. Apparently the support is hollow and fills with water and does not drain. Was really weird driving so low to the ground and the clutch was grabbing way at the bottom of the travel. No power steering felt a little weird too. Anyone know if there is a source of tower sections to replace the rusted area?
Left side looking rearward
Right side from under tranny looking at oil pand and jack behind right front tire
Right side looking in wheel well above steering arm
Closeup of left side solid
Closeup of right side ripped apart
On the trailer
After welding a small bracket
Closeup of bracket repair on leading edge of frame just above front A arm bushing
