gear choice - Page 3 - Fuelly Forums
Old 04-12-2006, 04:16 PM   #21
Where are you getting these
Where are you getting these numbers from?
Old 04-13-2006, 07:58 AM   #22
Send a message via AIM to molecule
https://asia.vtec.net/specs/
http://asia.vtec.net/specs/
i own the 3-stage and i owned the vx for a few years...
BE ZEITGEISTED
molecule is offline   Reply With Quote
Old 04-13-2006, 07:48 PM   #23
Interesting then. Would you
Interesting then. Would you also propose that a y5 head would yeild similar results then?
Old 04-14-2006, 07:00 AM   #24
GasSavers_Ryland's Avatar
where do you get the ECU for
where do you get the ECU for the 3 stage v-tec?
I've thought that getting one would be sweet as they have a higher redline, so that most likely meens better balencing, better bearings, even if I didn't get the matching ECU/wiring.
Old 04-14-2006, 08:51 AM   #25
I think since he's using a
I think since he's using a chipped ecu he must be using a 2 stage ecu then having an rpm activated switch to kick in the 3rd stage.
Old 04-15-2006, 07:44 PM   #26
yeah...i saw a 3-stage ecu
yeah...i saw a 3-stage ecu on ebay last week for $180...
uh...no thanx...plus i would have to convert to obd2...
and then i cant edit my maps...
i'd rather sacrifice being able to use a scangauge and stay obd1
i converted the distributor connector for obd1...
but later found out any 92-95 NON-VTEC dizzy w/ blue tach wire (i think all of them) is exactly the same as the 96+ dizzy's...
the y5 is a 1.6L engine...it uses more fuel...plain and simple...
all the 96+ heads are identical as far as their casting...
even the 3-stage
the difference is in the cams & rockers only
they all use the same valves...(except the gx propane industrial motor)
i added iab control to my ecu to engage the 3rd stage
but i used the 2nd method which didn't work...
i think i need to use the first method on this page
have yet to try it
if all else fails...then rpm activated switch it will be...
http://www.pgmfi.org/twiki/bin/view/Library/AddIABToP28
BE ZEITGEISTED
Old 04-15-2006, 07:47 PM   #27
You could always do the 1
You could always do the 1 wire vtec like they do with OBD0. Where the a/c clutch is used for the second gear or the automatic transmission thing. I dunno if they've cracked that code for obd1 yet. Mehbe you can turn a shift light or some other signal into the second solenoid signal.
Suggestion: Other ideas for comparing cars' data jjmatt33 Fuelly Web Support and Community News 6 08-08-2008 02:38 PM
VX rear wheel hubs -anyone replaced theirs? jadziasman General Maintenance and Repair 13 06-15-2007 12:16 PM
tire warped because of too much psi kickflipjr General Fuel Topics 30 04-24-2007 01:09 PM
Happy Holidays everyone! Matt Timion General Discussion (Off-Topic) 10 12-29-2005 12:07 PM
vegpowered systems GasSavers_Diemaster Vegetable Oil and BioDiesel 2 09-08-2005 05:53 PM
