2TonJellyBean -
Originally Posted by 2TonJellyBean
Is that even safe?
I think it has to be strong enough to handle the gas line's PSI. I have a fuel heater for my hydrogen-booster system, but my mechanic didn't want to install it because of safety issues. From what I have read, the real problem is "vapor lock". I *think* the best fuel heater is one where you can somehow control the temperature :
Vapor Lock
http://autorepair.about.com/cs/gener.../bldef_856.htm
Definition: When gasoline overheats and boils inside the carburetor bowl or fuel pump of a hot engine, it ceases to flow. This can cause stalling or hard starting. This is called vapor lock, and it usually happens during hot weather. If a hot engine won't start, all you can do is let it sit and cool off. You should check the cooling system to see if anything is causing the engine to run unusually hot (a bad thermostat or cooling fan, for example). Switching brands of gasoline may also help.
Fuel heaters are common for diesels in the northern climes :
IN-LINE FUEL WARMERS
http://www.arctic-fox.com/sitepages/pid43.php
* Stainless Steel Construction
* No Moving Parts
* Maintenance Free
* A Model for Every Application
* Easy Installation
* Thermostat Optional
* 5 year, 600,000 mile Warranty
I am sure that these fuel warmers would be "butch" enough to handle the fuel line pressure, but they wouldn't prevent vapor lock. You would need a "shut-off thermostat" for that :
Shut-Off Thermostats
http://www.arctic-fox.com/sitepages/pid63.php
FEATURES AND BENEFITS:
* The Arctic Fox "Series 400" shut-off thermostat stops the coolant flow when the fuel flowing through it reaches approximately 78? F/ 25? C to 95? F/35? C.
* The "Series 440" shut-off thermostat operates at a range of approximately 104? F/40? C to 125? F/52? C.
* Helps keep the fuel within the recommended temperature limits for maximum horsepower as suggested by engine manufacturers.
* With the shut-off thermostat you can convert your existing or any coolant type warmer into a thermostatically controlled fuel warmer.
* Utilizes proven sensor module technology used in engine coolant applications.
The problem with these is that you can't program the shutoff temperature,
. For GasSaver purposes, we would want to control this.
