Fuel Heater (wrap Around Coolant Hose Or Exhaust Pipe??) - Page 2 - Fuelly Forums
Old 09-17-2008, 06:14 PM   #11
I think if you want to heat your fuel, you should go to biodiesel.infopop. They have alot of stuff for heating fuel. You could do a hose in hose setup, where coolant runs all around the fuel line, or you can use injector heaters that wrap around the lines and apply electric heat, or an FMHE like mentioned above.
Old 09-18-2008, 05:43 AM   #12
Fuel at 900*F.... vapor lock and BOOM!
John
'09 Saturn Aura 2.4L
'96 Chevy C1500 (5.0L 5sp)
'01 KTM Duke 2
Old 09-18-2008, 06:07 AM   #13
Yeah but after the boom at least the vapor is unlocked.
Old 09-18-2008, 03:57 PM   #14
GasSavers_maxc's Avatar
With no "02"in fuel heater, no boom. It fuel system works like your house furnes. Has after market FI system. Fuel is heated after the injectors. The engine is wired up with plenty of high temp gauges.
less lurking and more working
Old 09-19-2008, 03:07 PM   #15
Did you mean to say "With NO O2 in fuel heater no boom"? How can you heat the fuel to 900 degrees, AFTER the injectors, and without O2?Don't the injectors inject it into air?You gotta share a little more! Jim
dutchdivco is offline   Reply With Quote
Old 09-19-2008, 07:02 PM   #16
Oh that's easy. Just eliminate the intake valve. Use direct high pressure injectors to squirt the fuel vapor into the chamber @ 900F. Then the second injector shoots the exact volume of liquid O2 during the the compression stroke. The high temp gas vapor causes the liquid O2 to change to gas completely right before TDC. You'll get an ultra high compression ratio, complete burn and awesome power.
https://www.maxxgraphix.net
maxxgraphix is offline   Reply With Quote
Old 09-20-2008, 08:24 AM   #17
Yeah, easy, lol So we just have to machine our selves a new cylinder head, or two. Couldn't be simpler!
AmachinistJeff is offline   Reply With Quote
Old 09-20-2008, 04:29 PM   #18
What? You don't have a 5 axis CNC? I thought that was a typical garage tool now.
Old 09-20-2008, 05:27 PM   #19
[QUOTE=dutchdivco;119047]Did you mean to say "With NO O2 in fuel heater no boom"? How can you heat the fuel to 900 degrees, AFTER the injectors, and without O2?Don't the injectors inject it into air?You gotta share a little more! Jim[/QUOTE
So you want me to tell you how to make a "deflagration burn too pulse detonation burn piston engine fuel system"? Go ahead and look it up. NASA working on some. Of coarse with no pistons. Very difficult too build they may have "reed valves" or something more exotic to turn the impulses on and off.
hi new member here and ive got some sick ideas! csrmel Introduce Yourself - New member Welcome 6 10-18-2007 02:23 PM
Miss matched tires zpiloto General Fuel Topics 4 02-16-2007 01:40 PM
