Fuel Additives Poll - Fuelly Forums
View Poll Results: Do you use fuel additives, and if so, why?
I do not use them, they're a waste of money! 23 42.59%
I use them for periodic fuel system cleanings. 17 31.48%
I use them for lubrication to combat the affects of E10. 3 5.56%
I use them both for cleanings and lubrication. 11 20.37%
Voters: 54. You may not vote on this poll
Old 06-29-2010, 01:48 PM   #1
Fuel Additives Poll
just wanted to see the mood here(and why) for fuel additives NOT for the purpose of gaining efficiency. no doubt most here would tend to lean towards the thought that additives do not increase fuel mileage.
please feel free to add comments about your choice if you so desire.
Old 06-29-2010, 03:19 PM   #2
add|ct's Avatar
Its funny you started a topic on this. It was recently on my mind as well, after reading around about the problems with using certain ones w/ E10 myself the other day.
What I've decided on is using a cleaner/lube with a gasoline like Shell V-Power(or just buy an entire tank of V-Power =P) My intervals are for every 4k or so, then I'll use something like SeaFoam in my gas tank, but not a very concentrated dose nor more often than every oil change, though I've done that before.
My dad uses Lucas' standard Fuel Treatment on his cars, and from time to time I'll slip some in. I don't want to really use a fuel treatment all of the time by any stretch while running gas with ethanol, but those 2 I'd use sparingly to help with any potential problems caused by having E10. I guess that's my attempt at finding a good balance between the extremes and not waste a lot of money either way.
When I've tried to get a used car "up to snuff" here's what I usually do:
- Drop a can of SeaFoam or Lucas in a smaller amount of gas(or more or less what each product specifies); I have used SeaFoam in other ways like in crankcase so that is partly why I bought it to transition between Type II oils to a Type IV(though AutoRX is probably a better option in hindsight)
- After that tank, replace the Fuel Filter
- Then proceed with other potentially affected parts needing service/replacement
I'm cautious about over treating, since of course using the 'cleaners' and 'upper cylinder lubes' tend to decrease gas mileage some during use and who really knows the potential damage to regular/continued use with E10.
Any more than 1 time every 3-5k miles is over treatment, IMO.
'92 Civic VX, Canadian model
Old 06-29-2010, 04:16 PM   #3
I haven't had any problem that I felt calls for a fuel additive, so I haven't tried any. I find that normal scheduled maintenance is quite sufficient for my vehicles and conditions.
The one exception was when I put some liquid that turned out not to be gasoline in my truck and it barely ran. I tried pouring some additives to clean it up, to no avail
Old 06-29-2010, 07:20 PM   #4
I use fuel stabilizer in the one ton van that we only drive once every few months, and in the other vehicles I use a bottle of BG 44k every couple of years to clean out the fuel system.
Old 06-30-2010, 09:28 AM   #5
I gave up on fuel system additives.
I tried 4 or 5 of them. STP, Lucas, Seafoam to name the few I remember. Didn't notice anything but FE dropping for the tank I added them but didn't substantially raise for the following tank. I deemed them a waste of money and stopped using them.
I've run the gauntlet of oil system additives too... same results. Some seem to clean better than others, but nothing really "solves" a problem if that's what your objective is.
John
'09 Saturn Aura 2.4L
'96 Chevy C1500 (5.0L 5sp)
'01 KTM Duke 2
Old 06-30-2010, 12:23 PM   #6
i don't recall having any fuel related issues before E10 made its way into our fuel. marine and small engine owners seem to have more frequent issues i've heard.
both of our DD are nearly 14 years old, so my thought was that maybe these vehicles would have long term issues at some point. what i've researched suggests that fuel cleaner are not so much needed anymore w/ alcohol in gas. there's likely a trade off however--like lack of lubricity.
Old 06-30-2010, 12:43 PM   #7
I'm pretty sure lubricity isn't an issue, there's additives for that already in the fuel.
Marine and small engine owners having difficulty may have carburetors that were designed for fuel that has MTBE or no oxygenator at all, not E10. It also affects carbureted cars. Besides different vaporization characteristics, it also is not safe for materials for which old formulas were safe.
Old 06-30-2010, 01:09 PM   #8
I know in VA gasoline sold at marinas and airports for air & boat usage does not have ethanol.
Old 06-30-2010, 01:50 PM   #9
this...http://www.fuel-testers.com/is_gas_a..._e10_list.html suggests that no fuel additive should be used w/ E10 or 85--at least not as a cleaner.
Old 06-30-2010, 04:21 PM   #10
add|ct's Avatar
I agree w/ btg.
I read the same article when reading around. Since I don't have the experience, just to be 'safe'; in relation to upper cylinder lubing, I just use something like Lucas or SeaFoam sparingly.
It seems like its more of an issue if a car sits a month or more with the same gasoline in it, being E10. That's another reason why I don't fill up my lesser driven car. Even the VX I don't fill up all of the way.
Why did it take me so long to find this place? Baranfin Introduce Yourself - New member Welcome 6 05-31-2008 05:17 PM
hi new member here and ive got some sick ideas! csrmel Introduce Yourself - New member Welcome 6 10-18-2007 02:23 PM
