Filter catch can - Page 3 - Fuelly Forums
Old 06-16-2006, 01:44 PM   #1
Dyno? 1/4 times?
Old 06-16-2006, 02:14 PM   #2
LincolnW's Avatar
Originally Posted by SVOboy
Dyno? 1/4 times?
No dyno times. I street tuned it. Well, I gave it a rough tune then went to the drag strip and fine tuned it there. I would datalog all of my 1/4 mile runs then go back over my AF ratios and play with my timing to see how it affected the run.
The best I was able to pull in the 1/4 was 13.6 on street tires. It would burn the tires all the way through 3rd if I pushed it. It was definately a fun setup.
I got pretty good milage with it as well believe it or not. When I only boosted a few times a day and drove mostly in vacuum I saw an increase of 3-6 mpg over what I was getting NA. But on those sunny Friday afternoons when I would blast down the high way at full boost... well, FE went out the window. lol
LincolnW is offline   Reply With Quote
Old 06-16-2006, 04:34 PM   #3
Because it's easy enough to just let the stuff burn up and I assume they'd assume that people would forget about them and they'd get clogged or that jiffy lube would do the same, hell, if jiffy lube can let a oil pan bolt fall out they can mess up the can or forget it.
Old 06-16-2006, 04:39 PM   #4
zpiloto's Avatar
Good Point. I forgot the only thing most drivers want to do is turn on the AC.
Old 06-16-2006, 04:41 PM   #5
You can also figure that most people would just empty it into their neighbors' lawns,
Old 06-16-2006, 05:17 PM   #6
What's that mean?
Old 06-24-2006, 02:29 PM   #7
Take the filter out of the inside of the thing, it'll get clogged and then the oil won't fall out.
Old 06-27-2006, 05:52 PM   #8
you can get bigger filters right? I think im gunna do an oil change first before i go do this, or do it all at once tonite
SupraRXZ is offline   Reply With Quote
Old 06-27-2006, 05:55 PM   #9
You can get bigger ones, yes.
On another note: If you're getting milky junk in there you have a blown headgasket! Yay, it's a diagnostic tool as well.
Old 06-27-2006, 09:11 PM   #10
Did an oil change and got one from HD, Putting it on was sorta a *****, but in the tube there was hecka gunk in there already so i cleaned it out, and well hopefully it works good
RSS feed for friends activity udtrev Fuelly Web Support and Community News 2 07-26-2009 12:47 AM
Suggestions needed Matt Timion Fuelly Web Support and Community News 80 03-28-2009 05:37 AM
Grille blocking jcp123 General Fuel Topics 15 06-09-2008 04:03 PM
Home built ramps from 2x10's? brucepick Experiments, Modifications and DIY 18 08-01-2007 08:29 AM
1995 Civic DX HB joins miwolf Introduce Yourself - New member Welcome 11 06-25-2007 09:00 PM
