Filter catch can - Page 13 - Fuelly Forums
Old 06-13-2007, 06:01 PM   #121
Stay true to the Game!
popimp's Avatar
Does the PCV valve need to be removed? Also is this good for fuel injected vehicles?
Old 06-13-2007, 06:59 PM   #122
No to #1,
and, Yes to #2...
Old 11-10-2007, 07:19 PM   #123
Send a message via AIM to GasSavers_andyj Send a message via Yahoo to GasSavers_andyj
Just now installed - Do I cut the white filter off and reinsert the plastic pieces or do I remove all the plastic pieces all together? Looks like no redirect just a hole inside. Guessing that the catch will be there as it is the lowest and the coolest point either way as long as the filter is removed.
** Great idea here - small unit right for my no room engine compartment **
Let me know...
GasSavers_andyj is offline   Reply With Quote
Old 11-11-2007, 05:35 AM   #124
Found answer - the suggestion of 2mm hole in the bottom of the filter makes sense to me to prevent clogging but keep turbulence going. Surprising how tough this little white filter is, I drilled a 1/8" hole in the bottom.
Thank you - hope this posting helps others.
Let the testing begin.
Andy Johnson
Save on Gas:
http://tinyurl.com/22cnyh
Old 06-27-2008, 10:11 AM   #125
Why silica beads over copper BBs or maybe a Chore Girl copper pot scrubber? I'm looking for the best catalyst to put in my filter bowl. Any thoughts or experiences?
OleDawg55 is offline   Reply With Quote
Old 06-30-2008, 08:10 AM   #126
SolidLiquidSnake's Avatar
I have one of those on my PVC but the thing is I don't have the filter, just the little catch can or jar that I used. It's worked wonders, I have gotten water/oil from getting into engine and it's not like I have to empty it everyday, it's small and never a lot of fluid in the can.
SolidLiquidSnake is offline   Reply With Quote
Old 07-03-2008, 06:05 AM   #127
Jim T.'s Avatar
I've put one of these in the Mazdaspeed and it only has about an ounce of oil in it after 3k miles. And it's turbocharged.
I had one in my Contour and the intake and throttle body stayed MUCH cleaner after installing.
I don't understand why these are not standard on every car.
Jim T
Ignorance is lack of knowing; stupidity is false logic
Jim T. is offline   Reply With Quote
Old 07-03-2008, 07:03 AM   #128
Probably because you'd have to empty them. People aren't used to removing fluids from their car, only adding or changing. If I understand correctly, the usual design is to burn off all that stuff.
Old 07-03-2008, 01:12 PM   #129
jprich's Avatar
Unhappy Soooo.....
...I think this is a great idea! I stopped by Home Depot but they only had a filter that had a release on the bottom of the reservoir. It was the Husky brand and kind of heavy. I passed on it and am going to check Lowes.
I got home and checked to see if I would need any extra hose and found this:
Im thinking the hose I need to filter is #1 as it contains the pcv filter. If so would making that hose longer cause a reduction in efficiency?
If its NOT #1 which hose is it?
jprich is offline   Reply With Quote
RSS feed for friends activity udtrev Fuelly Web Support and Community News 2 07-26-2009 12:47 AM
Suggestions needed Matt Timion Fuelly Web Support and Community News 80 03-28-2009 05:37 AM
Grille blocking jcp123 General Fuel Topics 15 06-09-2008 04:03 PM
Home built ramps from 2x10's? brucepick Experiments, Modifications and DIY 18 08-01-2007 08:29 AM
1995 Civic DX HB joins miwolf Introduce Yourself - New member Welcome 11 06-25-2007 09:00 PM
