Filter catch can - Page 11 - Fuelly Forums
Old 11-02-2006, 12:32 PM   #101
GasSavers_TomO's Avatar
Not to step on any toes here, but a slightly cheaper version of this DIY catch Can can be had at your local auto parts store. I did the exact same thing as SVOboy in principal but spent less. I purchased a FRAM fuel filter #G3 for $4 and placed it in the valve cover vent and the PCV system, like so:
Honda Civic VX Info/Links
Old 11-02-2006, 12:37 PM   #102
Noice!
Old 11-02-2006, 04:39 PM   #103
|V3|2D
thisisntjared's Avatar
um that filter looks like it will clog WAAY to quick with oil. other than that, sweet!! i would cut a small hole somewhere to let the pcv system continue to do its job even when clogged, by small hold i mean 1mm diameter.
Old 11-02-2006, 05:34 PM   #104
Yeah, the filter is small in stature but I check it daily. The one that runs from the valve cover to the intake tube has been on for over a week with not even a hint of oil in it. The one that is on the PCV system has about 3 drops of oil in it now and has been on for 4 days. They are easy to pop off and drain when/if they begin to fill up.
Old 11-02-2006, 10:37 PM   #105
Originally Posted by thisisntjared
um that filter looks like it will clog WAAY to quick with oil. .
True . it will clog.
The air flow of that fiuel filter will also be less that what you generate with blowby , so you can expect oil leaks from everywhere., and made much worse when that paper element gets soaked in oil , blowby will not pass then at all.
PSSSSSSSS - POP
Its a sucky idea
Old 02-19-2007, 07:42 PM   #106
civicduty_'s Avatar
Well lets give this a shot...!?
Originally Posted by SVOboy View Post
So I decided to give this DIY oil catchcan a try and see what's develops. My first thought was to pay a visit to Home Depot as SVoboy had suggested before but it was a good 30 min. drive compared to other stores nearby. So instinctively I took the shorter route, well that turned out to be a bad choice lol. Ace hardware had very limited products, Sears asked way too much for their Craftsman air line filter($38) and while at Pepboys, I took the chance to purchase some rubberized pvc hose. By this time I was losing hope and gas not to mention. Up next was between Lowes and Home Depot...Home Depot it was but sadly I could not use the same Husky $10 air line filter pictured above, it was not the appropriate size for my valve cover outlet. I had no choice but to choose the larger 100ml with 3/8" fittings. I'll post up some pics as soon as I have the chance to install, the cool night crept up on me so I grew weary.
civicduty_ is offline   Reply With Quote
Old 02-20-2007, 05:18 AM   #107
There's a 100ml size? I should get that. My small one fills up very quickly and needs to be drained after almost every tank.
Old 02-20-2007, 04:09 PM   #108
GasSavers_nathan's Avatar
mine fills up even before my tank runs out. usually half of it is ice. i have to bring it inside and let it thaw before i can empty it.
a real pain but at least i know its doing its job.
GasSavers_nathan is offline   Reply With Quote
Old 03-03-2007, 02:55 AM   #109
My catch can is a an old air filter use on large pneumatic industrial machines. Made out of nylon, lexan and stainless steel mesh, it is rated at 150 psi... not that its going to be seeing any positive pressure in this application. Its 5" tall by 2.5" wide.
The bottom half unscrews for easy cleaning.
Installed between the crankcase oil separator and the intake hose.
I haven't driven it yet but I'll update when I put a few miles on the setup. The best part: It was free
Old 03-03-2007, 05:28 AM   #110
Secure
After a body shop fooled with mine and sucked up the gunk into the intake manifold, I can't stress enough, the importance of securing the catch can to something. tjts1, it looks like you've done it right.
I can see most of us (including myself) having it hang mid-line and use the tightness of the connectors to ensure the proper alignment, but if it's bolted to something, the error of defeating the purpose of the device is minimalized.
For me, that would mean additional length of hose. Ensure that PCV hose is used. It can withstand the corrosive liquid, and the suction -- the parts store should know exactly what you're requesting (if not, run!) Outward pressure hoses like fuel lines don't take vacuum into consideration and can collapse under the Vac over time from heat in the engine bay.
RSS feed for friends activity udtrev Fuelly Web Support and Community News 2 07-26-2009 12:47 AM
Suggestions needed Matt Timion Fuelly Web Support and Community News 80 03-28-2009 05:37 AM
Grille blocking jcp123 General Fuel Topics 15 06-09-2008 04:03 PM
Home built ramps from 2x10's? brucepick Experiments, Modifications and DIY 18 08-01-2007 08:29 AM
1995 Civic DX HB joins miwolf Introduce Yourself - New member Welcome 11 06-25-2007 09:00 PM
