Filter catch can - Page 10 - Fuelly Forums
Old 07-06-2006, 04:36 AM   #91
ZugyNA's Avatar
Originally Posted by 95metro
So, what do you think, guys? Should I take the free Condensator?
Condisales says they don't have much feedback from Metro owners and my "review" could not be used as a user testamonial since it was a free unit. I guess as long as I posted a review of the product on Gassavers then people who actually look for information could find it and judge for themselves.
I'm not certain how I could quantify any results as yet, plus I haven't even owned the car long enough to have a yearly or normal baseline established as to my average FE.
I think I could objectively test it even though I have my doubts as to its actual fuel-saving capabilities.
Worse comes to worse, I guess it's a free catchcan. What do you think?
Maybe MetroMPG would be the better recipient since he's the testing guru.
Condisales is supposed to be sending me one. Just give it a fair test?
Old 07-06-2006, 06:18 AM   #92
95metro's Avatar
Yeah, I'll be fair about it, but until I get a MID there probably won't be any definitive results and I think because of how it works and what it is connected to that an A-B-A test will prove absolutely nothing.
Plus, tank to tank tests are already extremely variable so I doubt we are going to see any kind of repeatable results at all.
95metro is offline   Reply With Quote
Old 07-06-2006, 08:01 AM   #93
zpiloto's Avatar
You're right about not having the sMID and the tank to tank varibility but if it gets the results claimed you won't need the sMID. 20% of 55MPG is 11MPG. Which as you know is a huge gain, more than the normal 2-3 MPG usually seen. If you don't change the driving techniques or add any other mods that will take a lot of the varibility out of it. So just hook it up and see what happens and let the chips fall were they may.
Old 07-06-2006, 12:29 PM   #94
ZugyNA's Avatar
Best comparison might be the Suburu Legacy at EPA 23 to 25 mpg combined. With a gain of 4.5 mpg...this = around a 19% gain.
But every car is different..............as the saying goes.
With my Tercel 4WD 1.5L...baseline in the summer is around 30 mpg combined....and I generally drive it consistantly. So if I see 35-36 mpg I'll probably notice it.
Old 07-06-2006, 12:33 PM   #95
ZugyNA's Avatar
Originally Posted by kickflipjr
It seems like my catch can filled up faster when i was driving more highway.
So you can make a catchcan out of anything with an inlet/outlet for air? Seems easy and cheap enough.
These are pretty specific plans...derived from some experience. Use this design or learn on your own?
Old 08-29-2006, 06:10 PM   #96
Updated and www.crxmpg.com/pcv.html
If anyone has pictures to show the thing in action, lemme know,
Old 08-29-2006, 06:26 PM   #97
kickflipjr's Avatar
So, after 2,000 or so miles my catch can is nearly full.
2008 EPA adjusted:
Old 08-29-2006, 06:30 PM   #98
Mine totally dropped off on the fill rate, Iono why, but I don't mind,
Old 08-29-2006, 06:49 PM   #99
zpiloto's Avatar
After I hooked mine up for about two tanks it was full of this yellowish substance. I thought that the head gasket was going but it stopped and I have not seen anything since. I'll put it on any car I own. Mine need to be empty about every 3000 miles.
Old 10-26-2006, 06:42 PM   #100
UfoTofU's Avatar
I installed one about 1000 miles ago. The gasket between the plastic resevoir that fills up and the threaded head of the filter itself keeps moving out of place. Like it is getting sucked into the resevoir. Is this normal? Is the vacuum enough to move the gasket out of place?
- UfoTofU
UfoTofU is offline   Reply With Quote
RSS feed for friends activity udtrev Fuelly Web Support and Community News 2 07-26-2009 12:47 AM
Suggestions needed Matt Timion Fuelly Web Support and Community News 80 03-28-2009 05:37 AM
Grille blocking jcp123 General Fuel Topics 15 06-09-2008 04:03 PM
Home built ramps from 2x10's? brucepick Experiments, Modifications and DIY 18 08-01-2007 08:29 AM
1995 Civic DX HB joins miwolf Introduce Yourself - New member Welcome 11 06-25-2007 09:00 PM
