FFT Fuel Catalyst - Fuelly Forums
Old 05-04-2006, 03:40 PM   #1
FE nut
diamondlarry's Avatar
FFT Fuel Catalyst
I have completed my first tank of gas using FFT Fuel Catalyst. My previous best tank before FFT was 42.66 mpg. Without changing my driving style and temps being pretty much the same, my mileage jumped to 45.28 mpg. The dosage level is 1oz/10 gallons. At $19.95 for 16 oz, this figures out to be $1.25/10 gallons. If I figured right I saved just short of $.37 for this tank after figuring in the cost of the additive. Not bad.
2007 Prius,
Team Slow Burn
Old 05-04-2006, 05:01 PM   #2
philmcneal's Avatar
what's the science behind
what's the science behind it? Links please!
Old 05-04-2006, 05:30 PM   #3
FE nut
Oops, I knew I forgot
Oops, I knew I forgot something. I guess I was too excited about the good numbers. Here's the link to their homepage. http://www.futurefueltechnologies.com/default.htm I think he can explain it better than I can. Basically, it helps the fuel combust more efficiently.
2007 Prius,
Team Slow Burn
Old 05-05-2006, 05:41 AM   #4
Moderator
GasSavers_DaX's Avatar
FFT = fast fourier
FFT = fast fourier transform?
What is this stat? cavale Fuelly Web Support and Community News 1 09-03-2008 08:23 AM
