Originally Posted by lunarhighway
that was my first thought but than i'd still have to use a relay for the ignition, as that will have to be constant on, and only interupted when the switch makes contact.... i"m not sure if that's a good idea or not
True, forgot about that. How were you planning on tying into the ignition system? Could you use the circuit that trues off the car from the ignition cylinder?
