I've got the goods!!!
most of them i should think:
as mentioned it my LED question thread i finally decided to go for a dual button system.i was considdering a single paddle swich opperation, wich i could still make.
i'm building this into my fold out garbage bin, but since i want to be able to stow the bin i can't have anything projecting beyond the edges so buttons where more handy, plus the LED's will add a cool effect, and aid at night.
the people in the shop where very helpfull, when i got the switches the guy mentioned i'd need resistors asked me what voltage i'd use and simply grabed two resistors from a bin. according to the color code they're 562 ohm, 5% tolerance, that's about what i'd calculated... should give me about 18mA so that looks fine.
i also got a little buzzer wich will act as a powersaving device by alerting me when i've left my headligths on. apparently this was an option 20 yeas ago.
my car does turn of the headlights automaticly, but only after about 2 hours...by draining the battery.
here's a some relays i found in the attic... they're probably pretty old, but they still work fine and the left one is even so kind to tell you what's inside! how thoughtfull. i plan to use this as a breaker swich for the ignition, it will be driven by the stop switch.... guess wich color i'll use for that one.
here's the garbage bin (wich i doubt the privious owner even found by the look of it!...it looks factory fresh on the inside...i feel a bit sorry to drill holes trough it) i'll fabricate some sort of front plate to accept the buttons.
stay tuned for more pictures of this stuf being put together, silly questions, and perhaps some explosions...
