electric fan conversion - Fuelly Forums
Old 08-14-2008, 08:24 AM   #1
I have a 94 nissan 4x4 pickup witha 4 cyl. this truck came with a 160 degree thermostat, and always runs cool. I removed the fan and added an electric fan. in stop and go traffic in temperatures over 90 degrees, I have to turn the fan on every so often, otherwise, I never use it.I have thought about installing a 180 degree thermostat, but I rather enjoy not having to worry about overheating.
mikehallbackhoe is offline   Reply With Quote
Old 08-14-2008, 08:32 AM   #2
You're worried about overheating with a 180? Most cars come with 195's from the factory. Even my 1981 Buick came with a 195 from the factory. In the 18+ years I've owned it the car has never even gotten close to overheating. You'll probably get better FE with a warmer thermostat.
EDIT: Your heater will work much better in the winter if you up the thermostat too. I had a 180 in Rusty for a while when he had some overheating problems, and the heater did not work as well.
Old 08-14-2008, 09:08 AM   #3
GasSavers_BEEF's Avatar
you can also get thermal switches that will cut on the fan for you at set temps.
I would run a 195 so that your engine stays nice and warm and you get the best mileage out of it.
Old 08-14-2008, 08:20 PM   #4
kamesama980's Avatar
I almost never use the efan in my S10 4 cyl. I gotta be sitting for a while idling before it even gets to 190 and I've never gone over 200 before a light turned green BTW I have a 180f t-stat, factory is 195
-Russell
Old 08-14-2008, 10:04 PM   #5
the only thermostat available for my truck is the stock 160 and an optional 180. I will probably switch to the 180 . if you have ever had a vehicle with a heating problem, you can become gun shy about increasing the running temp.
Old 08-15-2008, 04:52 AM   #6
Site Team
The electric fan stopped working on my Saturn about 18 months ago.
I never fixed it.
I do mostly highway driving. As long as I'm moving at least 25 MPH, the engine will stay cool, even with the A/C running. If I'm stuck in traffic I turn on the heat (happened about 3 times in 18 months) - not pleasant, but I just haven't had time to fix the fan.
-Bob C.
p.s. I'm not suggesting you remove your fan, I'm just illustrating how little a fan is really needed. (I cannot run A/C when I'm parked or stuck in traffic, obviously)
Old 08-15-2008, 05:38 AM   #7
the 180 will help your MPG
COMP is offline   Reply With Quote
What savings have you been able to reach? Ashmck General Discussion (Off-Topic) 7 02-20-2008 12:12 AM
Converting numeric to current tire sizes. omgwtfbyobbq General Maintenance and Repair 5 06-01-2007 05:51 AM
Need help with stickers for the wheel skirts lovemysan General Fuel Topics 2 11-15-2006 11:30 PM
